Firmware upgrade fail
Postby Hoecken » 13 Nov 2016, 20:28
Just installed latest stable version and after entering activation key a message said "please upgrade
firmware to version 20141103". I clicked on OK and got "Firmware upgrade failed".
Can someone tell me what that means.
My 4 axis MK2 was purchased several years ago and I'm just getting around to using it. I hope it will work
with the latest software.
Hoecken
Re: Firmware upgrade fail
Postby Support » 14 Nov 2016, 10:05
Please see your PM inbox.
Postby Hoecken » 14 Nov 2016, 19:07
Thank you, I'll try that this weekend.
Hoecken
Postby Frank_L. » 05 Feb 2017, 09:30
Hello,
I have the same problem. The MK2/4 is new, but wasn't installed for three years.
When I connect it the firmware should be updated. But then the following message is displayed: "Firmware Update FAILED! (Unknown1)". I also tried an manual FW update. The LED have the following status:
Power is green
USB CONN is orange
USB UP is red
Status is blinking
Best regards
Frank
Frank_L.
Postby Frank_L. » 18 Feb 2017, 11:53
Any answer for the question?
Frank_L.
Postby Shawn Gray » 22 Mar 2017, 20:40
Support,
Last week we setup a CNC that has been in storage, it has a Planet-CNC MK2 board installed. It had an older version of the software on the system. After deleting the complete folder and installing the latest version and we, we tried both the manual reset and the software reset, but the firmware Version update 20141103 would FAILED! (Unknown1) or (Unknown)
The About screen
SW 2.10.1701.1001
HW 2012.03.30
SN 1158 CNC
We recently purchased a new MK3/4 board to upgrade the equipment, but we need to have the original MK2 board working to confirm the hardware, before changing the connectors on the assembly for the new board.
Thanks,
Shawn
Shawn Gray
Postby rex2005 » 23 Apr 2017, 21:29
Have same problem with Firmware upgrade and dont seems to work with activation ether.
Anyone know the trick?
rex2005
Postby gorenc2 » 25 Apr 2017, 08:44
You must ubgreiding step by step contat suport four instrucions!
gorenc2
Return to Mk2 controller
