PCB plate for tool lenght sensor
Postby thegardener » 25 Jun 2012, 20:55
I just watched in some videos that there are people using a empty pcb board with two wires soldered as a tool lenght sensor.
Are the input 5 and ground both soldered in the pcb board? or one in the PCb board and the other in the spindle??
If one it's connected in the spindle, in what part of the spindle i need to connect it??
Thanks!!
thegardener
Re: PCB plate for tool lenght sensor
Postby Andrej » 25 Jun 2012, 22:03
Input 5 is connected to PCB, ground is connected to spindle.
Andrej
Postby thegardener » 26 Jun 2012, 13:02
Nice!
Connected like that is working, I activated sensor in the inputs tab, when i touch the spindle with the pcb, it makes contact.
But suddenly I can home my machine, the home button appears gray.
I'm trying to calculate my machine size, do the calculations for homing, etc...but I can't jog.
It's so weird.
thegardener
Postby thegardener » 26 Jun 2012, 13:07
And the limits switches are working (they flash in the screen when I hit it) but they don't stop the axes.
Everything was working fine.
thegardener
Postby Andrej » 26 Jun 2012, 14:10
Check your sensor connections. Perhaps it is picking interferance.
Andrej
Postby thegardener » 26 Jun 2012, 14:43
it's working now!
Thanks!
thegardener
Postby wilfred1970 » 12 Jul 2012, 18:23
and for larger non-metal products: alu kitchen foil sticked on top--->measure/warp--->remove foil and MILL!
wilfred1970
Postby Hammer » 22 Jul 2013, 07:35
Is this for DIY board? Which pin does input5 corresponds to? I wish i had a tool length sensor...
Hammer
Controller: DIY Mk1
Postby Andrej » 22 Jul 2013, 12:16
LIMIT Z-
Andrej
Postby andyred » 19 Jan 2018, 17:04
sorry to revive an old thread like this, but this is not working with latest version of CNC USB Controller. The menu is completely greyed out and from I understood warp function only works with mk3 board.
Is there any previous version of the software which works with the probe?
andyred
Controller: DIY Mk1
Postby andyred » 19 Jan 2018, 20:41
with what software version does this work exactly?
andyred
Controller: DIY Mk1
Return to DIY
Users browsing this forum: No registered users and 0 guests
