Buffer error
CNC USB Controller Software
Buffer error
Postby bryanbranham » 25 Jun 2015, 03:22
I bought my machine new from Probotix in April of 2013.
I think it is a MK1 controller (green board with blue screw headers that has probotix screen printed on it) but I'm not sure, I had the same issues when I first bought the machine but ended up storing it till recently.
Any way I'm having issues with a "buffer error" box stopping my machine, and I am looking for away prevent this so that I do not have to stay with the machine to complete my programs. My guess is a lower feed rate but I am hopping for another solution.
software is up to date, firmware says it is.
cutting less then 20 IPM (inchs per minute)
new usb cable
filtered power on my router motor to help with AC noise
windows 7 64bit 2.9GHz laptop 4gigs ram, with the auto power cut off, turn off for usb ports
performance setting set to high
bryanbranham
Controller: Probotix Mk1
Re: Buffer error
Postby Support » 29 Jun 2015, 07:25
If your g-code (also please send us your g-code program and your settings file) is consisted from large number of small lines, which are represented as instructions for controller you may have buffer problems when using Mk1.
Mk1 buffer has only 14 instruction locations. Communications between PC (CNC USB software) and controller must be flawless in order to machine works fluently. Sometimes computer "assignes" priority to hard disk (light flashes on computer panel) and therefore slows down the CNCUSB controller software, which results as lower rate of instruction sending.
Buffer empties (jerky movement)
CNCUSB Controller senses empty buffer and speeds up the rate of instruction sending.
PC at one moment resolves priority to hard drive and CNCUSB controller software sends at current high instruction sending rate one instruction too many. Buffer is now full, and software gives error.
Possible solutions:
1. Lower speed
2. Program without so many short lines
3. More powerful controller (Mk3 series....)
Also:
All devices that are connected so same root hub need to share bandwidth.
Never use any USB 1.0 devices connected to same root hub as controller.
You can download this tool
http://www.planet-cnc.com/files/usbtreeview.zip
It will show you tree of all devices connected to your root hubs that share bandwidth. You can try to rearrange them and give controller more chance to communicate with high speed.
Re: Buffer error
Postby thomas6142 » 26 Dec 2016, 19:18
Hello. I seem to be having buffer issues with my setup. Running the Mk3/4 board. About a minute after I start the g-code my machine stops. I am trying a 3d carve with a tapered endmill (1/16" tip) so yeah producing a lot of short lines. Using V-Carve Pro: 50 inch/min, .06" clearance pass stepover, .01" stepover.
Windows 10 64 bit
2.2GHz processor
6GB ram
beer mug.nc
(809.99 KiB) Downloaded 20 times
settings mk3.setting
(49.84 KiB) Downloaded 21 times
thomas6142
Return to Software
