the fourth axis, how to connect and configure USB controller
Postby mokvo4 » 14 Mar 2017, 12:05
The fourth axis, how to connect and configure USB controller MK3 / 4, software PlanetCNC-TNG_20170305_beta
Product description
new 57 stepping motor, worm gear reducer, a slowdown of 20: 1
is a ship 80 for the cartridge 4;
feature description:
use a 57 step motor current is 3A
worm gearbox, 20: 1 speed ratio of the output torque is large.
simple structure, high precision, self-centering chuck is suitable for wood, metal, jade, and so on..
cartridge type:
Model: 80-4
Center height: 71 mm
overall height: 110 mm
fourth axis pulse setting:
the Mach3 system settings: 1 the extent necessary, the number of pulses
(1 lap driving pulse number of fines) 83019 on the perimeter
for example, two motor phase, fines 8 gear ratio 20: 1
1 set. depending on the angle
32000/360 (degrees) = 88.88888888 (counts)
2 schedule setting schedule length or circumference
32000 83019 (125.6 mm length) = 254.777 (counts)
what settings must be set in software PlanetCNC-TNG_20170305_beta?
I apologize for my English - machine translation
mokvo4
Re: the fourth axis, how to connect and configure USB contro
Postby Support » 17 Mar 2017, 11:34
Postby mokvo4 » 17 Mar 2017, 12:21
Links for which you have specified for the axis: "X,Y,Z ", I'm interested in the rotary axis "A" options in the first post
mokvo4
