Three point contact probe using my MK3/4 controller
Postby dakman » 08 Mar 2017, 14:35
I have fabricated a stepped aluminum block that fits onto a corner of material to be routed. I know there is a procedure for using the probe contact in the Z axis to set the Z offset to the material top face. Is there a way to use the current tool bit to then touch the left and then bottom sides of the touch block to also set the X and Y axis?
Things I know:
* the height or thickness of my touch block.
* the distance from the left and bottom outside edge of the touch block to where the step interfaces with the material.
* the tool diameter.
I know I could write some g-code to do all the moves but is isn't clear to me how to get the X and Y signal or do I just trigger off the same Z axis set line?
OK all you smart folks, discuss and tell me the right way to go about this..
Thanks in advance! :oops: ;)
Stephen
dakman
Re: Three point contact probe using my MK3/4 controller
Postby Support » 17 Mar 2017, 11:45
You could use Measure offset XY -> Corner inside/Outside of Center inside/outside
Please post some images of your idea and how you would like to use it?
Postby dakman » 16 Jul 2017, 23:55
OK...back from a long winters nap...
I have my Z-axis touch working based on the the input #1 that is triggered when the tool touches the touch block and seems to be working fine.
Is there a similar method to get the x and y touch to work like the Z?
Is there a way using G-code to sense the #1 input changing state?
discuss, all you smart people! :cry:
dakman
Postby Support » 31 Jul 2017, 14:33
