Planet CNC Stepper Driver - Microsteps issue
Postby ciutateivissa » 16 Aug 2016, 09:39
I´m running following Planet CNC components since about 3 years:
3x Motor Driver (2,5 A) / 1/2 microsteps
Mk 2/4 Controller (USB)
Now I changed my CNC hardware to something bigger, but kept the controller stuff, including the stepper Motors (1.8°, 2,0 A).
In my new setup I use trapezoidal screws (12mm) with a pitch of 6 mm. So I wanted to change the micro steps to 1/4 to have a propper resolution for the machine. The new calcultion would be: 200 x 4 = 800 / 6 = 133,3334.
So I changed the dip Switches directly on the Motor Driver board and entered the new values into the software.
The result was, that the travel distance of the machine was doubled - insted of 10mm, the machine now goes 20mm!
It seems, that the Motor Driver still works with 1/2 and didn´t accept the new dip switch setting.
Any ideas?
ciutateivissa
Re: Planet CNC Stepper Driver - Microsteps issue
Postby Support » 16 Aug 2016, 14:18
Are you sure that the DIP switch combination is correct? Can you post any pictures of the DIP switch when being configured to 1/4?
Pitch of screw is indeed 6mm?
Postby ciutateivissa » 16 Aug 2016, 15:50
the lead srew (trapezoidal) should have a pitch of 6 mm - at least that was written in the (german) specification:
Präzisions-Trapezgewindespindel RPTS TR 12X6-P3 C35 rechts 100cm mit besonders hoher Steigungsgenauigkeit.
Technische Daten:
Länge (L): 1m
Gewinde: 12x6 P3 rechts, zweigängig, gerollt. nach ISO 2901/2903 und DIN 103
Steigung (P): 6mm
Durchmesser (D): 12mm
Gewindequalität: 7e
Kleinstmaß Flankendurchmesser (D1): 10,191mm
Größtmaß Flankendurchmesser (D1): 10,415mm
Kerndurchmesser (D2): 7,84mm
Steigungswinkel: 10°30´
Steigungsgenauigkeit auf 300mm: 300µm
I´ve attached a picture of the dip switches.
ciutateivissa
Postby ciutateivissa » 17 Aug 2016, 19:29
finally solved the problem myself:
I asumed, that the Position "ON" would be "H" (high) - but that was wrong!
Actually the "ON" Position is "L" (low)! The letters L and H are on the left besides the dip switches, not easy to find ;-)
One could question now WHY the "ON" Position is used as low, but...
However, it works now.
BR, Ralf
ciutateivissa
