Easy to make SD card adapter [MK2]
Postby Moonglow » 22 May 2012, 05:44
Materials:
1. MicroSD card with adapter to full size card.
1. IDC-10 connector
2. Wires
Solder wires to sd card full size adapter
Code: Select all
EXT [MK2]          SD CARD
2(GND)             6(GND)
3(3.3V)            4(3.3V)
4(GND)             3(GND)
7(SDSCK)           5(CLOCK)
8(SDSSEL)          1(CS)
9(SDMOSI)          2(DI)
10(SDMISO)         7(DO)
between 3 and 4 contacts of SD CARD adapter put capasitors 0.1uF and 200-400uF ( better to use ceramic for about 10uF instead of electrolyte ). No need to use pull-up resistors... so it is realy simple solution. Just insert your microSD card in full size adapter and have fun ! )
p.s: For long life using better to buy Andrej adapter
sd card adapter pinout
assembled version of adapter
top view
Moonglow
Re: Easy to make SD card adapter [MK2]
Postby skillalot » 23 May 2012, 06:38
What is the status of the whole SD-card option Andrej?
What can we do with an SD-card at this moment?
Regards,
Sascha
skillalot
Postby Moonglow » 23 May 2012, 06:48
You can run toolpath w/o PC ( file must have name toolpath.raw )... in future it be more powerfull :)
Moonglow
Postby Moonglow » 27 Mar 2014, 08:38
More usable version with cheap chinese Arduino SD Card module ( ~$1.5 with free shiping 8-) )
1. Arduino SD CARD module
2. Remove PLD-16 socket, do it with heater fan
3. Prepare wires with IDC-10 sockets ( in my case i use second socket to connect external display board
4. Use solder to connect wires to sd card module
5. Optional, use glue gun to fix wires
6. If you do all this steps your adapter will work fine with MK2 board and looks like this
Moonglow
Postby Andrej » 27 Mar 2014, 19:44
I just want to warn that this is OK for Mk2 but on Mk3 is slightly different.
Postby subculture » 16 Jun 2017, 16:01
On Mk3/4
DATO- MISO
CMD - MOSI
SCK - CLK
? - CS
power and GND easy enough. SO anyone know where the CS pin connects to?
Andy
subculture
Postby Support » 20 Jun 2017, 14:15
We answered to you on CNCZONE.
viewtopic.php?f=2&t=10240
