chinese 3020 cnc power issue
Postby ndmb68 » 13 Mar 2016, 18:30
Ok was just getting the hang of the machine but now the spindle motor has no power no matter where the variable speed dial is turned too , Seems to be an issue as ive searched the net but to be honest i dont understand much of what people have done to resolve this , could someone tell me what i need to do in as plain a way as possible please :)
Andy
ndmb68
Re: chinese 3020 cnc power issue
Postby Support » 14 Mar 2016, 09:35
How have you connected your spindle with controller? Are you using our output board or only PWM signal from controller?
Postby ndmb68 » 22 Mar 2016, 08:38
the machine is wired as per instruction from supplier , from motors to a black control box with a variable speed knob on it
http://www.ebay.co.uk/itm/111792027629? ... EBIDX%3AIT
ndmb68
Postby Support » 23 Mar 2016, 08:22
Can you post picture of your controller?
Maybe the spindle drive circuit was damaged. Usually is controlled with freq or PWM signal from controller.
Take some photos of the equipment inside the cabinet.
Postby ndmb68 » 23 Mar 2016, 17:32
Problems with the control box seem quite common with these machines and im not able to diagnose of repair really , Is there an alternative spindle controller available ?
ndmb68
Postby Support » 24 Mar 2016, 09:33
you should be able to find it on ebay...
Postby ndmb68 » 24 Mar 2016, 21:45
Any reconsiderations ? Dont want the same issue again :)
ndmb68
Postby Support » 25 Mar 2016, 06:32
I suspect that controller in your control box is not our original product and therefore it is difficult to support it and give some proper advice. You intend to use the same brushed DC spindle?
Postby ndmb68 » 25 Mar 2016, 08:59
yes i do , could my box be modified by you ?
ndmb68
Postby Support » 25 Mar 2016, 11:14
You would probably need new spindle driver board.
Post some pictures of your electronic equipment.
