Heat Sink Attachment
Postby rwensley » 08 Mar 2016, 21:16
Greetings,
The Motor Driver 6A-256 has the power supply capacitors in a most inconvenient location leaving no good way to add a heatsink to the top.
Assuming the board uses heat vias, is the a picture available of the bottom of the board and pads for mounting a heat sink there?
Thanks,
Ron Wensley
rwensley
Re: Heat Sink Attachment
Postby Support » 09 Mar 2016, 09:53
You can use rubber flacks to fill the space between vias and the sink. Use thermal paste.
Driver mountClose.jpg (190.31 KiB) Viewed 1105 times
Driver mount.jpg (227.21 KiB) Viewed 1105 times
Postby Vikapolyak » 12 Jun 2016, 18:53
I see that there is a new and larger heat sink that removes the need for a fan. Is there a place I could order these from?
P.S.:
ЕСЛИ ЧТО-ТО НЕПОНЯТНО ВСЕГДА СМОТРИ СЮДА!
Vikapolyak
Postby Support » 13 Jun 2016, 09:03
Unfortunately we do not offer them. You can find them in some used electronic housing or circuits.
Postby ElaizaHob » 23 Sep 2017, 05:44
thats a great idean i never thought of that.
Thank you for the reply
Dan
ElaizaHob
