Wiring Diagram PiBot 2.2 to USB MK3/4 Controller
Postby Norcott » 25 Feb 2016, 10:25
Can you confirm pin outs between the boards, I have wired En – ans, dir – dir, clk – dir, dgnd – gnd.
However, motor will not rotate, occasionally get a pulse to motor but just vibrates.
Motor is ACT Motor 1PC Nema23 Stepper Motor 23HS8630B Dual Shaft 6-Lead 270oz-in 76mm 3.0A
Norcott
Re: Wiring Diagram PiBot 2.2 to USB MK3/4 Controller
Postby Support » 25 Feb 2016, 11:05
Can you post your settings?
http://www.planet-cnc.com/files/CNCUSBControllerMk34.pdf Page 8
Pinouts of our Mk3/4 and Pibot are not compatible. You would need to connect it with single wires
Postby Norcott » 25 Feb 2016, 11:18
I am using a custom ribbon cable so effectively they are single cables, if that's what you mean, and configured the connections as specified.
thanks
Norcott
Postby Norcott » 25 Feb 2016, 11:35
The unit was manufactured by Colin at RoboCutters if that's any help.
Norcott
Postby Support » 25 Feb 2016, 13:40
Postby Norcott » 25 Feb 2016, 14:08
This is how it is connected and doesn't work.
Norcott
Postby Support » 25 Feb 2016, 15:30
Can you make some pictures of wiring? And also settings file
Postby Norcott » 25 Feb 2016, 15:39
Cannot clear picture in enclosure of wiring.
CNCUSBController.setting
(49.51 KiB) Downloaded 86 times
Norcott
Postby Support » 26 Feb 2016, 07:44
In first post you wrote this:
Clk should not be wired to dir, it should be wiret to Pulse or Step, unless this is a typo.
Postby Norcott » 26 Feb 2016, 09:04
Support wrote:In first post you wrote this:
yes, that was a typo
Norcott
Postby Support » 29 Feb 2016, 13:22
Can you post video of the problem?
Have you tried changing the settings: Settings/Axes/Motor enable/Invert?
