Jog Board Speed Resister
Postby garysb56 » 01 Feb 2016, 04:49
I have installed a 10k pot so i can control the jog speed. I soldered three wires in the board where i thought a pot would be mounted but it doesn't work can you help me ?
i solder the three wires to three pins where the pot would mount
garysb56
Re: Jog Board Speed Resister
Postby Support » 02 Feb 2016, 11:18
Are you sure that pins of potentiometer are correctly connected?
Is anything moving? Or there only is no effect from the potentiometer no matter the value?
Postby garysb56 » 02 Feb 2016, 18:12
well i'm do sure but if you look at the board you see where there is a place for a pot and adjacent at are the three wire so thats how i hook them up and yes there is no change in speed when justing the pot.
garysb56
Postby garysb56 » 04 Feb 2016, 02:52
Support wrote:Are you sure that pins of potentiometer are correctly connected?
there is no effect from the potentiometer no matter the value?
garysb56
Postby Support » 04 Feb 2016, 08:28
Maybe this is the case? (user had wrong wires connected)
viewtopic.php?f=12&t=2319&p=11409&hilit=potentiometer#p11409
If you jump pins manually on the JOG connector is machine moving?
Is your keyboard enabled in settings? File/Settings/JOG/Jogging keyboard -> enable
Postby garysb56 » 11 Feb 2016, 20:02
You ask if it is wired correctly ? well its wired like the schematic you sent me ! and yes if i jump the pins the gantry moves appropriately. In checking for 3.3v there is none at the center pin of the pot and if i jump from the 3.3v to the input center pin the gantry moves "Y"+
garysb56
Postby Support » 12 Feb 2016, 08:21
Link that I have sent you was a post that was indicating wrong schematic. User connected 3.3V signal to middle pin which is wrong, I thought that maybe that was cause to your problem.
From pictures you have sent I can see that everything is connected OK.
Have you measured voltage between 3.3V and GND on JOG connector?
You said that when you jump 3.3V pin and POT pin Y axis moves? this should not happen...
Postby garysb56 » 28 Feb 2016, 02:14
Jog connector on the board like in the diagram ?
garysb56
Postby Support » 29 Feb 2016, 09:40
Yes, but the middle pin of potentiometer should be connected to POT pin of JOG connector.
Postby ddelarze » 29 Apr 2016, 13:18
Very nice enclosure frame, do yo have more pictures? Do you built it or buy it?
ddelarze
Postby garysb56 » 19 May 2016, 22:41
I built the driver box. Thanks
garysb56
