Control a laser by using PWM
Postby seppel » 25 Oct 2016, 17:53
Hello, has anyone experience regarding laser controllers under usage of MK2/4 and the CNC USB Controller software?
I've got a laser which is controllable by TTL (0V OFF / 5V ON; 0-20kHz). So, simply I could create a circuit which control the power manually by a pot and the Mk2/4 switches only completely on and off.
Are there any proposals in order to control the power by using the MK2/4?
Thanks for your advice.
seppel
Re: Control a laser by using PWM
Postby Support » 28 Oct 2016, 04:58
Mk2/4 can use PWM signal on its output, you can modulate signals duty cycle with S g-code. So you cold control your laser directly from g-code.
Postby seppel » 30 Oct 2016, 17:32
Okay nice. So I assume that I have to set the appropriate output pin in Output->Spindle & Coolant ->Output Pin -Velocity? But why the drop down menu there offers no choice. I can't select any pin.
seppel
Postby seppel » 04 Nov 2016, 17:46
Nice, but I can't edit the settings for Output->Sindel&Coolant->Output Pin - velocity. There is no drop down menu. What is wrong with my settings?
seppel
Postby seppel » 07 Nov 2016, 10:06
My board could output only a frequency modulated signal. So the duty cycle is always 50%.
seppel
