Dimension of Mk2/4 controller
Postby baoshi » 10 Sep 2012, 08:31
Hi Andrej,
Can let me know the dimension of Mk2/4 controller? I'm planning of upgrade my current DIY controller to a Mk2/4, but need to verify if it fits my casing first.
Thanks
baoshi
Controller: DIY Mk1
Re: Dimension of Mk2/4 controller
Postby Andrej » 10 Sep 2012, 10:07
Andrej
Postby GUnnar » 01 Mar 2014, 13:18
Hi!
What are the dimension of the MK3 board? Maybe you can add the MK3 board to the drawings.
Regards
Gunnae
GUnnar
Postby Andrej » 02 Mar 2014, 09:22
Mk3 is 110 x 105mm. Holes are 4mm from corner.
Andrej
Postby vegandiver » 04 Oct 2016, 05:15
Andrej,
the file you link to in this post is no longer active, do you still have this file? I am getting ready to purchase my next board and I'd like to get the hole dimensions correct so I can cut out my enclosure before the board gets here.
Thanks!
~Adam
vegandiver
Controller: None
Postby Support » 04 Oct 2016, 06:42
old.planet-cnc.com/files/Drawings.zip
Return to Mk2/4 controller
