Jog Speed & Goto Park 1 After Job Completes
Postby jdkerr » 02 Oct 2016, 20:47
Very new to using my PlanetCNC MK2/4 controller with a Probotix Fireball and had a couple of questions.
When Jogging (using the four arrow buttons as selected onscreen), I feel the jog speed is "slow" - and this could all be relative. I see the display says it is jogging at 979.02. How can I tell if I can jog faster or if this is a hard limit I have hit?
The second question is in regards to the Park 1 position. I am cutting pockets in a case and swap them out after each cut is complete. I would like to head to move to the Park 1 position after each job is complete, so I can remove the piece from the table. I am able to manually press to the P1 button after the job completes, but was wondering if there was an automagic way to have it done when a job completes.
Appreciate any feedback.
Thanks... John
jdkerr
Re: Jog Speed & Goto Park 1 After Job Completes
Postby Support » 04 Oct 2016, 06:47
Yes, if you use DXF you can set this in import dialogue:
In "Footer" you can insert G28 or G30 so when job is completed, machine will travel to these locations (defined in settings)
Return to Mk2/4 controller
