settings for plasma cutter with thc and tool sensor
Postby akles » 11 Aug 2016, 14:03
I am working in my homemade plama cutter table, and i'm having problems with the tool sensor ( plasma torch touch the sheet and need return some millimeters), my sensor is closing contact but the usbcnc isn't stoping the z axis and returning some milimeters
If some one heve a plasma cutter working with tool sensor and THC, please send me the settings
thanks
akles
Re: settings for plasma cutter with thc and tool sensor
Postby Support » 12 Aug 2016, 12:54
Please post your settings file and your program file. Post pictures of your Z axis mechanics and tool sensor.
Do you touch the plate manually with measure tool Z offset button or via g-code?
Postby akles » 15 Aug 2016, 17:16
Hello, i´m posting my settings, and i put a button direch on the mk 2/4 board in the imput 5 like in the photo, i made that because my mechanical z system are not ready.
when i import a dxf file and run in the computer and the z axis are going down i press the button simulating the tool sensor, but the z axis don´t stop and return some milimeters.
Settings.setting
(50.29 KiB) Downloaded 52 times
akles
Postby Support » 17 Aug 2016, 07:19
In settings set: File/Settings/Input -> enable "Use Sensor"
File/Settings/Tool Sensor -> For fixed tool sensor set Safe Height and Return Distance
Under View/ShowIO-> See if your Input 5 is properly triggered under input panel
Postby akles » 20 Oct 2016, 14:07
Hello again, i still have problem with tool sensor, when i click in" Tools - Measure tool offset " the sensor stops the z axis, but i can't make z axis stop and return some millimeters with my DXF files. There are some settings I need to know in DXF files ?
When the program are stoped, and i push the sensor, the program indentify the sensor( It is written down in the program display "sensor) but when the program is running that is not happening.
akles
Postby Support » 24 Oct 2016, 14:37
Please post again your latest settings file and have controller connected when you export them.
