Z problem
Z problem
Postby Sgoum » 13 Jun 2016, 06:20
When I try to cut my CNC does not go under ~1.9mm
Everything was working OK until yesterday when this started to happen.
I used WARP to engrave some PCBs and did not change anything in settings.
m24.setting
(52.66 KiB) Downloaded 59 times
Sgoum
Re: Z problem
Postby Support » 13 Jun 2016, 09:02
Please try these settings I attached:
m24.setting
(52.66 KiB) Downloaded 53 times
Re: Z problem
Postby Sgoum » 13 Jun 2016, 09:22
It is not working.
Everything is working ok except Z depth witch is constantly at 1.9mm
Sgoum
Re: Z problem
Postby Sgoum » 13 Jun 2016, 11:40
Here is a file that has problem
Total_GUI_Engrave_TOP.nc
(22.57 KiB) Downloaded 45 times
Sgoum
Re: Z problem
Postby Sgoum » 13 Jun 2016, 12:19
Something else I have just noticed.
I have a drill operation of -2 mm.
It drills only till 0.1mm thats a delta 1.9mm
Sgoum
Re: Z problem
Postby Sgoum » 13 Jun 2016, 13:05
If I type Z-2 [ENTER] it goes to Z 0,
If I type Z-4 [ENTER] it goes to Z -2
If I type Z0 [ENTER] it goes to Z 2
If I type Z 2 [ENTER] it goes to Z 4
Sgoum
Re: Z problem
Postby Support » 13 Jun 2016, 13:41
I saw that in your settings that you have first sent me, you had G92 offset for Z axis set to 2.
Open your settings file with notpad and search for G92 offset and look for value set for Z axis.
Re: Z problem
Postby Sgoum » 13 Jun 2016, 14:03
Changed it to Z0.0
Problem persists.
Sgoum
Re: Z problem
Postby Sgoum » 13 Jun 2016, 14:23
I have found it.
I have tried to run some files generated with Autoleveller.
They have changed a value in the .var file and set the z offset 2mm.
I edited the file end set the offset back to 0 and now it is working OK.
Thank you for your effort.
Sgoum
