Adjustment for speedramp
Postby pinto » 24 Feb 2016, 19:13
I just have a problem,
I cut a ,over a 100 times cut, pice on my mill.
Y- Axis: when I come on a straight line to a holdingtab, it slows down, (good) lifts the motor, goes 5mm (good),
back to workingdeph, (good) -----
but than starts with full speed (1200mm/min) and I loose steps. ( no ramp )
I do not know were I made the mistake in the settings or were it can be.
Greetings Michael
pinto
Re: Adjustment for speedramp
Postby Support » 25 Feb 2016, 07:10
Please post your settings file and your g-code.
Postby pinto » 25 Feb 2016, 15:50
here are the files
g-Colde line 107 it starts without ramp
Greetings Michael
Mechatronic 170x70.setting 24.02.16.setting
(52.58 KiB) Downloaded 35 times
Dissy Platte 1 neu.tap
(20.29 KiB) Downloaded 30 times
pinto
Postby Support » 26 Feb 2016, 08:40
I tried it but I could not recreate it, could you post a video?
