Joystick
Joystick
Postby buddhafragt » 08 Dec 2015, 08:56
I like to build a Joystick control for axis movement,
my Joystic have analog pots at the axis,
have someone a good idea, how to use it as axis movement with speed control?
best regards
Michael
buddhafragt
Re: Joystick
Postby Deltaflyer » 08 Dec 2015, 16:43
I have 2 "analog joystick for Playstation, Arduino etc." and an Arduino pro mini board a 4-axis JOG pad built. I read the Poteintiometer at the analog inputs A0 - A4 of the Arduino and a test if the pot. Value in middle or is against positive or negative. and the Arduino then for each axis to 2 digital outputs of the JOG + or JOG signal.
The Arduino board is a 3.3V board, since the JOG terminal only 3.3V are available. (MK3 / 4 controllers). For speed setting I have just a 10K log. Potentiometer connected to GND, + 3V3, and POT at JOG Port.
If you are interested, I can give you images, schematics, and send the Arduino code. The Arduino code contains instructions, but mainly in German.
Kind regards
Stefan
Deltaflyer
Re: Joystick
Postby uncommongrafx » 05 Apr 2016, 15:25
I would be interested in your info.
Thanks,
Robert
uncommongrafx
Re: Joystick
Postby Deltaflyer » 06 Apr 2016, 13:27
I provide the information for you together. What do you need anything? Available are schematic and board for Eagle or as pdf. Plus Arduino Sketch with German comments. Please send me a PM.
Best regards
Stefan
Deltaflyer
