Touch probe in cncusb Mk2/4
Postby akles » 18 Jul 2015, 23:29
I am making a plasma cutter with my Mk2/4 board, and i want to make my plasma head touch the sheet and return some millimeters until start the cutting, where in the program i can configure this, and where in my board can i put the sensor or button?
i want to make like in this video:
https://www.youtube.com/watch?v=HZlV4dUuvMI
akles
Re: Touch probe in cncusb Mk2/4
Postby Support » 20 Jul 2015, 06:43
You connect sensor to input 5 of the input connector.
User manual for Mk2/4(Page 19): http://www.planet-cnc.com/files/CNCUSBControllerMk24.pdf
In software you click:
File/Settings/Tool Sensor
Software user manual(Page 160,161,162): http://www.planet-cnc.com/files/CNCUSBController.pdf
Postby akles » 28 Jul 2015, 00:11
Hi, thanks for your help, i made the tool sensor configuration and the z axis are not stopping and returning when the sensor are activated, i am working with DXf files, I need make some configurations first when i am opening the DXF file ??
akles
Postby Support » 30 Jul 2015, 09:19
Please send us your settings file:
File/Export settings
Postby akles » 31 Jul 2015, 01:09
Here are the settings file.
settings.setting
settings file
(48.94 KiB) Downloaded 69 times
akles
Postby Support » 31 Jul 2015, 07:19
First, let us see if your tool sensor is correctly sensed by controller.
In settings you need to have enabled Settings/Input -> Use Sensor
You connect the movable sensor to the IN5 of the Mk2/4 controller. The "tool" should be connected to GND input of controller.
See user manual for better clarification(Page 19):
http://www.planet-cnc.com/faq/moveable_sensor/
Postby akles » 10 Aug 2016, 21:25
hello again, I am trying again make my touch probe work correctly on my plasma cut table. I am sending my settings again to you to see if you can find the problem, and a picture with my manual switch to work like the tool sensor.
it is right ? please, can you send me a settings that the tool sensor is working, or resend my settings with corrections?
thanks.
settings(akles).setting
(49.7 KiB) Downloaded 25 times
akles
