DB25 connector on Mk2/4
Do you use DB25 connector on Mk2/4?
Yes
11
31%
No
17
49%
I don't have Mk2/4
7
20%
Total votes : 35
Postby Andrej » 10 Mar 2014, 07:28
I'm interested to know if Mk2/4 owners use on board DB25 connector?
Re: DB25 connector on Mk2/4
Postby Brian » 17 Mar 2014, 13:59
yes
Brian
Postby Abcdeflijus » 28 Mar 2014, 13:32
No, until my controller is laying down naked on the table. I'm planing to do a homemade box for it, then I think I will find this connector useful to reduce amount of wires.
Abcdeflijus
Postby mechatronik » 28 Nov 2014, 10:49
My preference would be to have the DB 25 and the USB-connector together on one side of the board for easy external access when the board is installed in a box.
If this is too much of a redesign I would rather prefer a 26 pin ribbon cable connector than a DB 25.
Plus I would like to have other signals assigned to the DB25 as right now.
A typical set up is to have the motor drivers and the power supply in one box
and all the manual controls in a separate box/case closer to the machine.
Therefore for easy cabling I would prefer to take out the motor driving signals (step/dir) and replace them by the jog signals and pot signals.
regards
Horst
mechatronik
Postby cncmar » 09 Jun 2015, 09:02
yes. I use it for connection to Gecko G540. Works without prob.
rgds
M
cncmar
