4th axis keyboard commands different to program
Postby myfordvmb » 04 Jan 2017, 14:12
Using SW 2.10.1609.3001
HW 2014.11.03
SN 1721 CNC
Have XYZ milling machine with Rotary table as A axis. No anti backlash software settings on any axis.
I have problem in setting A axis to zero degrees position. I type commands A0, A1, A1.2 etc to get it into correct physical position. Then zero the A axis and confirm machine and work all read 0 and no offsets.
However when G code program runs it goes to wrong position. That is it does not return to 0 correctly.
What I have concluded is it appears typing in commands on the keboard behave differently to those in a program.
If I run a program
G21
G01
G90
A0
A1
A0
The A axis returns to the position it started a 0 correctly.
However if I type on keyboard as a command A0, A1, A0 it does not return to 0. It appears to have either gone forward to much or returned to little.
I can hear going in +ve direction it does not sound clean. But this is only from keyboard command. Runing as a gcode program its ok.
It is as if an offeset is having an effect on keyboard commands but not displayed on screen.
Any pointers to resolve this issue.
myfordvmb
Re: 4th axis keyboard commands different to program
Postby Support » 05 Jan 2017, 09:56
We will check this. But let me remind you that since you are using Mk2 version any firmware software fixes are unfortunately not possible.
Postby Firesand » 09 Jan 2017, 19:32
Support wrote:We will check this. But let me remind you that since you are using Mk2 version any firmware software fixes are unfortunately not possible.
Why are the MK2 firmware fixes not possible?
Are you dropping support for the MK2?
Are you only working on the MK3 now?
Please let us know.
Thank you
Firesand
Postby Support » 10 Jan 2017, 14:31
MK2 controller is not supported since it is obsolete. We are not dropping the support, we will help and investigate problems but if it turns out that for error is indeed bug's fault we will not make firmware changes.
We are occupied with development of new software which is now main priority.
http://planet-cnc.com/using-optional-pause-planetcnc-tng-software/
Postby myfordvmb » 12 Jan 2017, 18:04
So is this a firmware or PC Software issue?
Regarding Mk2 board. it does seem to have a number of issues. Only bought it just of 2 years ago from you :-(
myfordvmb
