How to configure output pins of Mk2/9 board
Postby MiechH » 10 Dec 2016, 16:56
The MK2/9 has 7 output pins for which i'd like to configure different functions. In the settings under Output/Pause&Move i'd like to assign "Output pin - G-Code" to output pin 3. However I can only select "--". The same counts for all of the other functions in the settings except "Output pin - Pause". I found out I can control them with g-code M62 Q.. (have to convert a binary code to decimal to make them work). What's the purpose of all these functions, and how can I assign them to the output-pins?
MiechH
Re: How to configure output pins of Mk2/9 board
Postby Support » 13 Dec 2016, 14:18
Yes, this is supported only with Mk3.
You can activate them via mentioned g-code, so you can insert these lines in your program at specific line.
