Limit switch become red but motor doesn't stop
Postby MarLi » 05 Dec 2016, 11:55
Hello,
Hopefully someone has the solution for the following:
On my MK2 board I connected limit switches NC in serie following the manual.
When i trigger the switch manualy the system response by giving a red tube but the motor doesn't stop. Even when I'm enable the invert function. The system does stop when I'm giving a e-stop by input 4.
Any solution for this to let it work? Then i can do the homming procedure.
Thanks!
Martijn
MarLi
Re: Limit switch become red but motor doesn't stop
Postby Support » 06 Dec 2016, 14:05
Please post your settings file. So your limit switches are NC and connected in series. This is for all axes?
So you use only three limit inputs? Limit 1 for X, Limit 2 for Y and Limit 3 for Z?
Try enabling "Single input" in settings under File/Settings/Limit.
Postby MarLi » 06 Dec 2016, 17:47
I've uploaded the settings. The box Singel inpu is enabled.
Z-axis NC one switch
Y-axis NC two switches in serie
X-axis NC two switches in serie
Hopefully you can see the reason what I'm doinng wrong :)
limit.setting
(49.75 KiB) Downloaded 27 times
MarLi
Postby Support » 07 Dec 2016, 11:10
How are your limits connected?
Describe all connections of limit switches, how are they connected and to which input..
Also configure your machine:
http://planet-cnc.com/how-to-setup-cnc- ... ontroller/
Postby MarLi » 07 Dec 2016, 11:36
Attached I've posted the way I connected it.
I use the 10T85U micro swtich and connect the wires to pin 1(C) and 2(NC) of the switch.
schedule limit.jpg (140.15 KiB) Viewed 546 times
MarLi
Return to Mk2 controller
