Problem z axis
Problem z axis
Postby Kostadin » 28 Dec 2016, 18:13
Hello. 2 days ago controller working normally. Today when I turned on System z axis automatically went down. What could be the problem. I do not use manual control.
Kostadin
Re: Problem z axis
Postby Support » 30 Dec 2016, 06:27
Please post your controller picture and your settings file.
Re: Problem z axis
Postby Kostadin » 30 Dec 2016, 09:47
Now I don't have a picture of the controller.
CNCUSBController.setting
(49.42 KiB) Downloaded 50 times
Kostadin
Re: Problem z axis
Postby Support » 05 Jan 2017, 10:12
Looks like you have one of Chinese counterfeit boards: viewtopic.php?f=2&t=520
We do not support these boards and therefore we cannot be responsible for any hardware or license malfunction.
You should turn to support and help to your merchant/seller that sold you this product.
However license that we provide should work with these controllers.
These boards are based on our first Mk1 controller which is obsolete and is not supported.
Many of its features are outdated and there is no software/firmware development.
It has a small buffer and weak processor, which reflects on bad machine performance.
You can purchase original controller or license in our web shop:
http://planet-cnc.com/products/
Re: Problem z axis
Postby Kostadin » 07 Jan 2017, 17:34
I use only the board of the Chinese. the license for the software I purchased back in 2012 year.The problem is solved - temperatures were quite low. after warming everything is normal. Thank you all.
Kostadin
