Speed problem with circles and splines
Postby anode » 01 Sep 2016, 16:24
I'm using MK1 on an K2CNC machine ( gekodrives)
I have the following problem:
Speed varies during a circle ( or splines), for example from setted 500 up to 1780.
In attachement my settings and a test circle
Speed increases at north and south part of the circle.
Thanks in advance for support
settings0109sera.setting
(50.59 KiB) Downloaded 85 times
testpattern.tap
(21.36 KiB) Downloaded 65 times
anode
Re: Speed problem with circles and splines
Postby Support » 02 Sep 2016, 10:27
You are using Mk1 controller which is under powered and outdated.
Can you post pictures of your controller?
Postby brummettm58 » 02 Feb 2017, 22:57
What did you do to fix this issue? My speed doubles or triples at both North & South ends of circles and squares. When the speed increases, it causes my circle to shift sideways about 5/8". Everywhere else it runs great. Why is this happening?
brummettm58
Postby Support » 03 Feb 2017, 11:30
Please post your settings and your g-code.
Postby brummettm58 » 01 Mar 2017, 23:28
Here is the settings file. I did "something" and it's stop shifting sideways (for now anyway), bu tmy speed still varies and is uncontrollable.
MKB Settings Modified.setting
(49.84 KiB) Downloaded 21 times
brummettm58
