Motors not moving
Motors not moving
Postby CContrata » 04 Jun 2016, 11:32
I just finished my CNC machine and I have everything hooked up, but the motors do not move at all, can't jog, nothing. This is what I have done.
At first, windows had errors so I went to Manual Bootloader Mode and updated firmware, with no internet connection. Windows driver error went away.
I then successfully activated with my code.
In the software, nothing is grayed out on the screen.
I can test cut in the software, but the motors never move.
With power off and USB cable disconnected, I Reseated all motor connections - no change
Power/USB disconnected, I reseated ribbon cable - no change
Changed USB cable 3 times - no change
Motors are getting power, but never move.
Curt
CContrata
Re: Motors not moving
Postby Support » 07 Jun 2016, 06:45
When you jog, the yellow tool in software is moving? Meaning, everything looks OK, you are just not able to move motors, correct?
Try this:
In File/Settings/Axes -> Motor Enable tab ; see if it is enabled, also change the "Invert" option
Postby CContrata » 07 Jun 2016, 20:42
Yes, when I jog the yellow tool moves but not the motors.
I do not have a Motor Enable tab, so I thought maybe I am running older software?
(Version I am running)
SW: 2.1021011.2701
HW: 0001.01.01
So, I downloaded the newer version that now has the Motor Enable tab, however it will not let me activate the license.
Curt
CContrata
Postby CContrata » 08 Jun 2016, 14:34
New software loaded, updated firmware, activated license, motor tab - Enable checked, "Invert" grayed out. Motors still not moving.
Curt
CContrata
Postby Support » 08 Jun 2016, 14:38
We urge to you use latest STABLE or BETA version of sw.
Could you post picture of your controller?
Do you have one of Chinese counterfeit boards: viewtopic.php?f=2&t=520
We do not support these boards and therefore we cannot be responsible for any hardware or license malfunction.
Postby Support » 10 Jun 2016, 06:38
Please post an image of your controller and post here your setting file: File/Export Settings file
Also post picture of your motor drivers.
Postby poolrod » 05 Sep 2016, 06:44
If you just put the step motors on, there is a small screw that needs to tighten to the step motor pin, or the stepper will run, but nothing will move.
poolrod
