MK1 and Drivers
MK1 and Drivers
Postby Fedgar » 30 May 2017, 19:49
I have a system based of a Fireball V90 that I purchased around 8 years ago.
One of the drivers has gone bad so I went and I purchased new drivers for all 3 axis.
Controller: [url][/url]
Drivers: [url][/url]
I am trying to figure out the wiring between the two. Currently I have the drivers wired as such:
+5VDC > +DIR and +PUL
STP > -PUL
DIR > -DIR
I have left Enable disconnected as the datasheet says to.
I would like to confirm I am wiring this correctly since the motor locks up like it is in holding mode... but never moves from there.
Any help is appreciated.
Fedgar
Re: MK1 and Drivers
Postby Support » 31 May 2017, 10:19
https://planet-cnc.com/how-to-connect-m ... ed-inputs/
Try also connecting the enable ipnut.
Then configure it in settings: file/Settings/Axes/Motor enable
Re: MK1 and Drivers
Postby Fedgar » 01 Jun 2017, 14:40
Thanks for the link. I can try connecting it with common cathode as well. See if that makes a difference.
This Mk1 driver doesnt have an enable output pin does it? So I am not sure how I would connect it, unless you mean to have me parallel the step or direction? Or just hook it up constant on?
Fedgar
Re: MK1 and Drivers
Postby Fedgar » 15 Jun 2017, 02:18
Alright, I read your message and didnt get a chance to mess with it until just now.
So looking at your schematic, I see a problem. I have no Enable output.
Also, I swapped the wiring from common anode to common cathode with no luck. I am not sure if the enable should be left off, or if it should be jumpered or grounded etc.
I supplied the board part number, its a planet CNC part, I was hoping someone here would have a or could make a general schematic.
Fedgar
Re: MK1 and Drivers
Postby Support » 15 Jun 2017, 14:16
See drivers manual regarding enable pin idle status.
Maybe you need to jump it to ground.
Post picture of your drivers and your controller.
Re: MK1 and Drivers
Postby Fedgar » 15 Jun 2017, 16:22
My original post has links to the drivers with spec sheets. As well as the controller model with what documentation I could find on it.
Fedgar
Re: MK1 and Drivers
Postby crazyjoker7070 » 13 Jul 2017, 05:39
have a nice day. USBCNC MK1 4 AXEN How can I resume from where I left off? In the current program.
crazyjoker7070
Re: MK1 and Drivers
Postby Support » 31 Jul 2017, 14:32
