Tool crash
Tool crash
Postby gibrocksonne » 01 May 2017, 14:55
I'm using Mk2/4 and the latest version of software (v2.17...).
I'm using a fixed tool sensor and a small piece of PCB as movable tool sensor.
I carefully followed the tutorial "How to use tool change?"
When not using tool change, a do a manual Z-zero at the stock surface using a paper sheet, everything works fine. But using the tool change procedure, I tried 5 or 6 time and every time I got a tool crash.
Please see details on attached pictures.
This is a mill test into a wood part but my next aluminum piece would not tolerate any error ;)
Thank you for your help.
setting 01-05-2017 axes,limits, tool ok.setting
(53.01 KiB) Downloaded 5 times
stock crash.JPG (146.7 KiB) Viewed 110 times
tool sensor.txt
(27.52 KiB) Downloaded 4 times
gibrocksonne
