PlanetCNC TNG feedback
What is your experience with new PlanetCNC TNG software?
I tried it on Windows OS and I like it
8
40%
I tried it on Linux OS and I like it
0
No votes
I tried it on Windows OS but I have problems
7
35%
I tried it on Linux OS but I have problems
2
10%
I tried it and I don't like it
0
No votes
Haven't tried it yet
3
15%
Total votes : 20
Postby Support » 01 Mar 2017, 14:49
We want to provide best user experience for our users that use PlanetCNC TNG.
Therefore we would be very grateful if you fill out poll that would provide us with some much appreciated feedback. What are your first experiences and impressions with new PlanetCNC TNG software so far?
We will be very grateful for any contribution of describing potential problem that you might have with PlanetCNC TNG . This would greatly help guiding us towards fixing these problems.
Re: PlanetCNC TNG feedback
Postby blowlamp » 03 Mar 2017, 19:39
The only real fault I've come across is that spindle synchronised movement for lathe screwcutting doesn't seem to be implemented yet.
Martin.
blowlamp
Postby Support » 06 Mar 2017, 14:44
Yes this will be implemented very soon.
Postby dudemeister » 12 Mar 2017, 00:37
Is the program status missing from TNG? In the old software I could see how much time was left running a project. I can't seem to find that in the new software. Also, I really miss the jogging control that the old software used. It was much easier to move my machine around multi-axis than the jogging bars provide in TNG. Anyway to add that option?
Thanks!
dudemeister
Postby TommyK » 30 Mar 2017, 08:08
Hey Guys,
Today i installed the latest Beta on Linux and got some trouble. after Installation i could not open the PlanetCNC64.exe.
It Only Starts directly after the Installation. Did i something wrong?
When its open i could not move the Axis with my Numpad like in the standard Version do you still plan to implement it?
The Biggest problem is that i could not rotate G-Code like in the old Version. It doenst rotate around my actual Zero Position. It looks like that it only rotate around the absolut machine Zero
I attached an Image what it does.
Thanks in advance
Tommy
Bildschirmfoto 2017-03-30 um 09.43.39.png (46.72 KiB) Viewed 2535 times
TommyK
Postby TommyK » 30 Mar 2017, 18:08
I got some Trouble with the "rotate Program" feature. everytime i try it doesnt rotate around my local Zero Position.
When the program is rotated and i change my Zero start point it moves in the wrong direction.
And the new Beta Linux Installer (2017.03.22) seams to have some trouble with the .exe, it only starts directly after the instalation. If i close the program i couldnt start it again...btw i didnt have much experience with linux.
thanks for your help
TommyK
Postby blowlamp » 31 Mar 2017, 16:13
Unfortunately screwcutting is not usable just yet, due to similar problems as described in my previous thread here: viewtopic.php?f=18&t=5022
Things are better in some respects, such as the tachometer display, which is now accurate with either Index or Encoder inputs and is great.
I'm still getting a thread pitch error though, but vastly reduced when compared to the software previous to TNG - I'd say by about 80% or 90%.
Using a G76 move with either Index or Encoder synchronisation, an effect I am seeing is of poor tracking of previous threading passes by subsequent passes and is highlighted by altering the spindle speed slightly as the tool returns to the start of the next pass - as if data from the last pass is still being used for the next pass. Athough the lathe carriage does change its velocity with changes in RPM, it isn't locked to it well enough for thread cutting of any sort. I have tried making alterations to the Debounce setting all the way from 0 to 10000 with no change in performance for my setup. One other thing I've noticed is that the Z axis return moves speed up on the spring passes too.
Many thanks, Martin.
blowlamp
Postby Support » 03 Apr 2017, 12:30
Please post your TNG settings, g-code program and the parameters of thread you are trying to achieve.
Please post also pictures of current workpiece which gives unsatisfactory results.
Postby Support » 03 Apr 2017, 12:33
@ TommyK : Please post your TNG settings and your program
Postby TommyK » 04 Apr 2017, 08:53
Here is my Settings- and a G-Code Sample file.
Archiv.zip
Settings file with g-code sample
(6.07 KiB) Downloaded 63 times
Thanks in advance!
TommyK
Postby Support » 11 Apr 2017, 09:24
@TommyK: We somewhat fixed this to make these features more user friendly. Although the concept that is currently used for these rotations etc is by the book.
Modifications will be included within next release of TNG software.
Postby TommyK » 13 Apr 2017, 04:53
Thanks for this information. I tested TNG on a Chromebook with linux and it worked really well. 6 hours nearly nonstop with absoluty no Problems. And i really like the custom Shortcuts. Great work guys!
TommyK
Postby wradix » 26 Apr 2017, 07:14
I'm only able to to Download the version ..06 and I'm not able to Import my setup datas from my Planet USB ...1001 Version, as well I'm not able to make the registration or activate the ..TNG Software.
Pleas help.
Wolfgang Radermacher (wradix)
wradix
Postby Support » 26 Apr 2017, 12:12
Please carefully read all steps from this link: https://planet-cnc.com/list-essential-p ... tutorials/
Best regards, Team PlanetCNC
Postby cpt Scorcher » 28 Apr 2017, 03:07
Clicking on the help menu item brings up a .pdf with no actual information ( just a printing template ) and the software download page only has a manual from 2014. I understand that a lot of it's the same as CNC USB SW but would be nice to have an actual manual for TNG. Especially for people who haven't used any planet-cnc software before and/or have their machine out in the back shed with no internet connection!!
Speaking of documentation putting some step by step instructions within the manual ( or another menu item under 'help' perhaps )for common activities would be nice, for example initial setup/calibrating, drawing import examples. Tutorials are good but I think common tasks should be included in a software manual. IMHO ;)
Oh and XHC pendant integration would be really good, even my old MACH3 SW could do that. :D
But on the whole I love the software especially for its ability to accept various drawing files and is well priced.
cpt Scorcher
Postby quangloi37 » 08 Jun 2017, 05:53
3D view is incorrect
quangloi37
Postby slbat » 20 Jun 2017, 18:02
Yeah, I'm looking for the TNG Manual as well. The one that came with the Install is just a "lorem ipsum" template.
slbat
Postby Support » 29 Jun 2017, 09:58
Manual should be finished in next weeks. Thank you for your patience.
Please note that visualisation of 4-axis g-code is not trivial and there is not correct way of displaying it.
We believe that TNG displays g-code correctly.
Postby hks11967 » 17 Sep 2017, 23:35
missing setup CTRL MPG Pendant Tool Table Tool Change ATC.
How I can rollback to the CNC USB CONTROLLER V2.10.1707.1201? Cannot finishing wiring hardware do to PlanetCNC TNG software. Please help for MK3/9 controller firmware rollback to CNC USB CONTROLLER V2.10.1707.1201.
hks11967
