New PlanetCNC TNG software released!
Re: New PlanetCNC TNG software released!
Postby Support » 01 Mar 2017, 14:51
@traderdays: In which window(tab) do you observe the M3 and M5 code? State? Speed?
Postby Support » 01 Mar 2017, 14:58
@DmacTheMaker2: Unfortunately Raspberry PI is not supported.
Postby traderdays » 01 Mar 2017, 15:05
Active M codes:
traderdays
Postby traderdays » 01 Mar 2017, 15:15
With G53 active TNG will not load a gcode program using G02, G03, or G04.
traderdays
Postby ojaatka » 02 Mar 2017, 14:28
This Question was asked before bot not answerd (or I missed it):
If I update my MK3 to this new firmware will I have any problems going back to the old version if there are problems?
So i will asked it for me again:
Can I change the firmware back, or is the previous software compatible with the new firmware?
Thanks,
Olivier
ojaatka
Postby pinkgoat » 03 Mar 2017, 21:11
Have you noticed that your webpage has been hacked ?
pinkgoat
Postby dudemeister » 06 Mar 2017, 03:28
I'm unable to upgrade the firmware. I installed the latest driver, and everything looks like the tutorial until I click on "upgrade firmware" at which point i get the following error:
Error message
I have the Mk3/4 controller and I'm using Windows 10. Any help would be appreciated.
dudemeister
Postby Support » 06 Mar 2017, 14:48
Have you updated you controller with latest CNC USB controller version prior to when you update it with TNG?
Postby pinkgoat » 06 Mar 2017, 17:21
: dudemeister
I had the same problem, my solution was to update the new firmware in the old software first,
then went back to the new software, and update the firmware in TNG.
pinkgoat
Postby ojaatka » 08 Mar 2017, 20:01
need your Help!
After I could successful update to TNG (means I already update to the latest firmware) today
this message appears:
Error Msg
This is my Device Log Output:
Device: VID: 0x2121 PID: 0x2130
Serial: 8458
Type: 1
SubType: 7
VersionMain: 20170301
VersionBoot: 0
RequestTimeout: 10
ResponseTimeout: 10
CommCnt: 392
RetriesSendCnt: 0
RetriesReadCnt: 0
ErrorTransferCnt: 0
DuplicateCnt: 0
Issue raised after updating to latest beta from 05.03.2017
ojaatka
Postby Support » 09 Mar 2017, 15:10
You tried to update controller from TNG 03.01 version to 03.05 version and you get this message?
Can you repeat this multiple times? And still no success?
Postby ojaatka » 09 Mar 2017, 15:38
Support wrote:You tried to update controller from TNG 03.01 version to 03.05 version and you get this message?
Yes
Support wrote:Can you repeat this multiple times? And still no success?
I tried it a few times. One time it seams to work (no message). But after next tim the message appears again.
ojaatka
Postby Support » 10 Mar 2017, 07:26
Controller is normally updated and works with the TNG 03.01 version?
Postby ojaatka » 10 Mar 2017, 07:29
Support wrote:Controller is normally updated and works with the TNG 03.01 version?
Yes, the controller worked with TNG 03.01 and was updated normally
ojaatka
Postby Support » 10 Mar 2017, 12:42
There seems to be some problems. This version will be fixed ASAP.
Postby dudemeister » 10 Mar 2017, 22:28
pinkgoat wrote:: dudemeister
That worked, thanks!
Not sure about how other feel, but I personally really liked the jogging controller in the old software. Is there a way that can be implemented in TNG? The XYZ single access manipulation is not as user friendly in this version.
Also, anyone having issues with the micro-stepping jog control? When I click on the arrows, nothing happens.
Thanks for the help.
dudemeister
Postby dudemeister » 13 Mar 2017, 05:43
Will TNG support 2D and 3D image files like the old software? I noticed that this feature and several other from the old software (better jogging controls, program information like run time) are missing in TNG. Is the plan to implement these in the official alpha release?
Thank you for working on this software!
dudemeister
Postby Support » 13 Mar 2017, 07:30
@dudemeister:
Jogging in new TNG is much better, what exactly are you referring to? you mean motion wise or jogging display keys etc?
Please post your settings file.
Postby Mar_cone » 13 Mar 2017, 19:45
I have a problem with the firmware update of my MK3 / 9 with tng software.
I upgraded software and the USB driver to the latest version, TNG recognizes me the MK3 board but none of it to update the firmware I tried so many times even after repeated reboots the PC but I can not. Tips?
Thank you
Marco
Mar_cone
Postby Jimmydee004 » 16 Mar 2017, 14:15
I have been using your MK3/4 controller and software for sometime now to run Arnold. My cnc is a three axis. Is there any reason for me to upgrade?
Looks like there is a bit involved to convert to the TNG software.
Jim Markevitch
Grapevine, TX
Jimmydee004
Postby dudemeister » 17 Mar 2017, 04:43
Support wrote:@dudemeister:
This is the jogging control interface that TNG has vs. the multi axis control in the old software.
Also, I might be missing it, but is there a program status bar missing? I can't seem to find the time remaining in a project in TNG.
Thanks!
dudemeister
Postby dudemeister » 17 Mar 2017, 04:52
Here's my settings file. Thanks for taking a look at it.
dudemeister
Postby Support » 17 Mar 2017, 11:15
@dudemeister: In new TNG version that will be released you will be able to have fixed jogging keyboard on screen in main display, much like in old sw. Status bar for now is still not implemented.
@marcone:
Yes, this seem to an issue with some users.
- Exit all software's, either CNC USB controller or PlanetCNC TNG
-turn off and disconnect controller, meaning disconnect power supply and USB cable. Controller needs to be completely without power and connection
-Start PlanetCNC TNG software and update FW.
Try this multiple times, be persistent. We have a feeling that this is more of a Windows related problem.
@jimmydee:
Please follow this link to successfully update your controller with TNG: https://planet-cnc.com/list-essential-p ... tutorials/
Postby dudemeister » 09 Apr 2017, 01:09
Support,
How can I revert the firmware back so that I can use the old software. TNG has a lot of potential, but I think it is too beta for me to have made the move. Can you post procedures for getting the old firmware on the controller?
Thank you
dudemeister
Postby Support » 11 Apr 2017, 09:48
Which feature is undeveloped for your taste? We appreciate any feedback
Please follow steps from this link in order to successfully update your MK3,Mk3/3 or Mk3ECO controller with TNG software, obtain TNG activation code, TNG license or how to revert back to old CNC USB controller software:
PreviousNext
