How to set machine and use offsets?
Re: How to set machine and use offsets?
Postby ybmdu » 20 Jan 2013, 11:53
Thanks to Denis for the french translation of this topic.
I have an MK2/4, and I try to define the limits on a 3 axis CNC.
I have mechanical switches on both end X and Y and one on Z+.
The thing is, when I check IO all the switch respond to 1 2 3.
When I come back to the control panel and move the switch, the Z switch light up the Y axis in red, the Y light up the X in pink.
So the problems start while trying to follow this helper.
Z axis switch wont make Z stop.
When I define 0 to X my machine wont stop when hitting the other end and same for Y.
So... Where is the problem ?
ybmdu
Postby Andrej » 20 Jan 2013, 15:32
Mk2/4 requires that "Single Input" setting is checked.
Can you verify this and post your settings.
Postby ybmdu » 20 Jan 2013, 15:56
Yes, I can continue now.
It was unchecked.
Thank you so much.
ybmdu
Postby T_Evans » 01 Jul 2013, 04:53
I just want to thank you for the excellent instructions. Once I got my limit switches sorted out the offset and homing piece went well. Everything worked the first time through. Hopefully I will begin some test cuts very soon.
Terry
T_Evans
Postby VNQUANG » 13 Jul 2013, 12:54
Because of your instructions are so valuable, I condense them into one document using instruction format. Please review and comment. It can distributed freely.
CNCUSB Settings.zip
(72.25 KiB) Downloaded 342 times
VNQUANG
Postby suli25an » 03 Jan 2014, 05:13
Dear Sir :
Is there a explanation with pictures ,How to set fixed tool sensor .
suli25an
Postby Andrej » 03 Jan 2014, 06:56
Postby suli25an » 04 Jan 2014, 04:44
Andrej wrote:Here are tutorials:
http://www.planet-cnc.com/faq/machine_setup/
Thank you very much for your reply and your interest.
suli25an
Postby suli25an » 04 Jan 2014, 04:46
Thank you very much ( Andrej ) for your reply and your interest.
suli25an
Postby megalo82 » 05 Sep 2015, 18:32
hi, i have an mk3/4 controller and the software version is 2.10.1505.3001 and i've tried so many time to follow this tutorial but my home button is still grey. Can you help me please?
cncusb.setting
(49.26 KiB) Downloaded 111 times
megalo82
Postby Support » 07 Sep 2015, 08:41
Is there any limit switch or sensor input activated?
Click "View/ShowIO" and make a screen shot of this panel.
Postby megalo82 » 08 Sep 2015, 05:55
yes! solved, thank you
since i have the 4th axis but i don't have limit switch on it, the 4th axis switch "invert" was on
megalo82
Postby safsalak » 02 May 2017, 21:22
thanks...
safsalak
Previous
