New STABLE version 2.10.1511.401
Postby Support » 28 Sep 2015, 14:05
Fixes:
-fixed limit switch issues
-fixed issues with "Go to - Zero XY "
-fixed issues with sudden accelerations when not starting program from origin
Re: New BETA version 2.10.1509.2701
Postby Firesand » 28 Sep 2015, 19:25
Thank you very, very much!!
Firesand
Postby Mammut » 29 Sep 2015, 06:45
Thank you very much, the issues are resolved.
Best regards
Manni
Mammut
Postby nicolap8 » 29 Sep 2015, 10:06
This is good but still some work to do: for all (many?) of us that use the keyboard it would be very good if the "tab order" in the dialog boxes could be corrected so we can use tha TAB key to navigate the dialogs!
nicolap8
Re: New BETA version 2.10.1509.2801
Postby nicolap8 » 29 Sep 2015, 12:47
Bug: now (don't know from version) il I load a program and do the "Set Grid /48009" the dimension of the grid are ever 64*64. In the past the size was got from the program size!
Bug: just tried a T1 M6 command now when I press "continue" it does not measure the tool. I haven't changed nothing in the config.
nicolap8
Postby Support » 05 Oct 2015, 07:19
Please send us your settings and g-code files.
Re: New BETA version 2.10.1510.501
Postby Support » 07 Oct 2015, 08:13
Fixes:
-fixed camera issues
-fixed issues with extruder axis for 3D printer
-fixed H-bot issues
-fixed PWM issues
Implemented:
-automatic power compensation for laser
-visualization support and direct integration for DevSoft, DevFoam Fuse software
-Multiple network adapter support
Postby Bakha » 08 Oct 2015, 10:18
previously, this had not happened,
Bakha
Postby nicolap8 » 10 Oct 2015, 10:38
nicolap8 wrote:Bug: now (don't know from version) il I load a program and do the "Set Grid /48009" the dimension of the grid are ever 64*64. In the past the size was got from the program size!
Update: the values are saved between sessions. This can be a good thing in other context but in this case I think the dimension of the grid can be associate only to program size.
nicolap8 wrote:Bug: just tried a T1 M6 command now when I press "continue" it does not measure the tool. I haven't changed nothing in the config.
For now I haven't time to work on this. I sorted it out inserting pauses (M0) and changing by hand.
New bug report (for this the beta exists :lol: )
- load g-code (image 1)
- zero offset
- Program -> Advanced -> Transform from points
- entered 3 points, the "from" by hand, the "to" moving and capturing
- saved points
- calculate, ok (image 2)
- checked the precision, not satisfied
- modify the points
- calculate, ok
*** now the program is moved with a wrong (bigger) offset! (image 3)
Note: when reentering the window the values of the calculation matrix are gone, resetted to default.
Other bug: in the same function/dialog Program -> Advanced -> Transform from points
- clear is necessary
- load "from" points
- load "to" points
- the "to" coordinates are displayed in the wrong place (image 4)
- the calculation is done correctly
Note: what does the "reload" command?
In the main windows, after applying a tranformation, checking the "offset" checkbox has no effect, are shown ever the absolute coordinates and not the transformed ones.
transform 1 before.PNG (3.77 KiB) Viewed 5550 times
transform 2 after 1 calculate - good.PNG (3.88 KiB) Viewed 5550 times
transform 3 after 2nd calculare - wrong.PNG (4.01 KiB) Viewed 5550 times
nicolap8
Postby nicolap8 » 13 Oct 2015, 13:16
Update on the Transform from points function: now I'm trying to use it really so I checked the precision. :evil:
Disappointing!
In the image you see
- "from": the entered coordinates
- last 4 lines of "to": coordinates of holes captured jogging the machine, the holes are 0.8mm and the bite can reenter in the hole
- first 4 lines of "to": the coordinates captured AFTER the calculation, moving the head using the "Goto selected line XY" command from the script
It seems that the calculation are not good because there are some important differences, see image and attached xls.
Question: which versione and which command can I use TODAY to have a corrent tranformation? :(
Note: in the dialog caption it's reported the number of point of Z Grid.
tranform entered and calculated.PNG (24.89 KiB) Viewed 5540 times
transform errors.PNG (10.98 KiB) Viewed 5540 times
transform errors.zip
excel data
(2.19 KiB) Downloaded 55 times
nicolap8
Postby Support » 13 Oct 2015, 14:53
We will check and test tommorow. Thank you for your understanding.
Postby nicolap8 » 13 Oct 2015, 17:55
I checked all measures and calculations:
- the distance from holes are correct to 0.1mm (measured with caliper)
- the matrix il calculated correctly
- applying the matrix to the coordinartes of 4 points I got the correct results (the error is less of 3 microns so is the roundings)
- divided the errors of the previous post excel: dX/dY and the result is, respectively
Code: Select all
dX/dY
24,5000
25,5000
25,5000
63,0000
These numbers can not be a result of a wrong measurement, wrong movement or else but only a miscalculation in software!
Attached the excel file with calculations.
transform errors 2.zip
excel file
(3.24 KiB) Downloaded 70 times
nicolap8
Postby nicolap8 » 13 Oct 2015, 21:13
I found where is the mistake in the last problem: myself!
I apologize for having wasted your time.
The presumed wrong calculation was due to a mistype:
Code: Select all
X82.55000 Y62.23000 Z0.00000 #0
X85.22000 Y3.81000 Z0.00000 #0
the second X coordinates would been the same of the first but I noted it only after dinner and some pause...
Now the error is under 100 micron, acceptable!!!
Lesson for me: check once more your data...
Nicola
tranform good.PNG (32.57 KiB) Viewed 5512 times
nicolap8
Postby Support » 14 Oct 2015, 07:44
Great, glad that everything is OK.
Postby Florida » 17 Oct 2015, 22:19
Was the problem with importing DXF files fixed in this version? I reported this in September. The safe height
was being calculated wrong when using Units = inches.
Florida
Postby Support » 19 Oct 2015, 07:22
Yes, this should be fixed.
Postby Florida » 21 Oct 2015, 18:59
Tested and working on my set up
Thank you
Florida
Postby ricky1209 » 24 Oct 2015, 10:47
In the "graphical program visualisation display" window, I'm not seeing it update unless the mouse pointer is in the window.... anywhere else on the screen and the window freezes.. bug??
ricky1209
Postby Support » 26 Oct 2015, 07:47
What kind of update are you talking about? Could you describe little more in detail this problem, i have trouble following.
Re: New STABLE version 2.10.1511.401
Postby antoine_non » 11 Nov 2015, 10:31
Hello
Trying to update this morning to new version
My antivirus (AVAST) detects a virus of type
Code: Select all
Win32:Evo-gen [Susp]
in file
Code: Select all
http://www.planet-cnc.com/files/CNCUSB_20151104.zip|CNCUSB_Setup.exe|{app}\CNCUSBControllerLib.dll
and blocks the download.
I'll stick with the current version until the issue is solved
regards,
antoine_non
Postby Support » 11 Nov 2015, 13:19
Set in Avast as "false positive".
Postby Bakha » 11 Nov 2015, 17:06
the previous version does not work, on the current version works, what is changed?
Bakha
Postby spaceman » 14 Nov 2015, 20:59
I updated to this version and now my Z axis limits do not stop the machine. If the switch is triggered the axis will continue to move in the direction of the switch however it will not move in the opposite direction. X axis, and Y axis work normally.
I posted a video https://youtu.be/QLJiWxia9vE
1511_401.setting
My settings
(53.85 KiB) Downloaded 74 times
spaceman
Postby juanpefrutos » 03 Apr 2016, 11:05
Good morning.
I installed the version 2.10.1511.401 and now I can not access the menu to calculate the transformation matrix . It has changed somewhat to calculate the matrix ?
Thank you
juanpefrutos
Postby Support » 04 Apr 2016, 13:27
Transformation menu is now accessible under:
Program/Advanced/Transformation from points
