thc floating head
thc floating head
Postby 125dduffy » 08 Sep 2015, 17:55
hi can anyone help me am using a mk1 controller form buildyourowncnc.com am trying to setup a floating head for my plasma table I have the moving parts working fine and I have it wired to my z limit I have it set it up to work as a tool sensor to find the top of the work and that works fine but how can I set up the g code so that it does the procedure and zeros the z height automatic before it cuts each new part during a running programme
plus I want to use sheetcam but does anyone now what post processor will work with this software
am really stuck wasted days on this would love a little help thanks.
125dduffy
Re: thc floating head
Postby Support » 10 Sep 2015, 07:33
Mk1 does not support THC function, which is used with external THC controller that controller the Z axis so that machine is cutting always on the same distance from the surface.
Our Mk3 series of controllers support G10 g-codes which can be used in the beginning of a program and can initiate the offset measurement and offset setting. The absolute value for Z is changed but you could use it like you have mentioned.
Postby tineoh » 22 Nov 2017, 18:18
Greetings, I have a USB controller by probotix (PBX-USB). Does this board support the Z floating head feature?
Best regards.
tineoh
Postby Support » 23 Nov 2017, 08:35
PlanetCNC forum will be closing.
PlanetCNC Support team
