Running two controllers from same PC
Postby StoveMan » 02 Jul 2015, 02:30
Hi support,
I have two boards and two licenses. One runs a router; the other a laser engraver. i would like to run either or both from my PC Can I instance more than one CncUsb software using different license files.
Do I need two computers?
Still loving my controller, rock solid!
Frank
StoveMan
Re: Running two controllers from same PC
Postby Support » 02 Jul 2015, 06:24
Yes you can use only one computer. You can create a desktop shortcut with different setting files.
You can have both .lic files in the install folder.
Here is the tutorial:
http://www.planet-cnc.com/faq/shortcut/
Postby dudemeister » 23 May 2017, 06:05
FAQs are gone. Can someone provide directions on shortcut commands to open the software with different settings files?
Thanks!
dudemeister
Postby Support » 24 May 2017, 14:15
Postby dudemeister » 25 May 2017, 15:51
Thank you!
dudemeister
Users browsing this forum: Bing [Bot] and 3 guests
