New STABLE version 2.10.1505.3001
Postby Support » 01 Jun 2015, 09:29
New stable version has been released and is available here:
http://www.planet-cnc.com/files/CNCUSB_20150530.zip
One thing worth mentioning is the use and location of transformation feature, which is now located in:
"Program/Advanced/Transformation from points" -> this is especially meant for production of double sided PCB's.
Full tutorial is coming soon.
Re: New STABLE version 2.10.1505.3001
Postby Firesand » 01 Jun 2015, 16:54
Can this new version be installed from scratch or does it have to be installed over top of a previous existing version?
Firesand
Postby Support » 02 Jun 2015, 09:08
Remove previous version from your computer or when you install the latest version just c/p the .exe and .dll files to your previous folder.
Postby Andrea_E636 » 02 Jun 2015, 16:57
Hello, I just installed the new version but unfortunately no longer opens files created with .dxf Autocad11.
I use Win8
Andrea
Andrea_E636
Postby Support » 03 Jun 2015, 07:27
You could normally import them with previous versions?
Could you send us this dxf file?
Postby Andrea_E636 » 06 Jun 2015, 08:05
Ciao
I can not open the file.dwg generated with Autoca11.
Quietly open the .dwg file in the folder examples.
With the previous version worked regularly.
Before reinstalling the SW I deleted the folder that contained the old version.
Grazie
Andrea
3005_1028Telaietto.dxf
(586.35 KiB) Downloaded 273 times
Andrea_E636
Postby ljs66bug » 06 Jun 2015, 18:33
Andrea_E636 wrote:Hello, I just installed the new version but unfortunately no longer opens files created with .dxf Autocad11.
I use Win8
Andrea
MIne as well a file I've been running will no longer open
ljs66bug
Postby ljs66bug » 06 Jun 2015, 20:12
I just downloaded this new version and it won't let me load my g code from mastercam anymore it's makeing every line and error is there a link to get the older versions back I can't find it anywhere and remember seeing a list of all of them somewhere thanks for any help
ljs66bug
Postby Support » 08 Jun 2015, 07:24
Please post your g-code from mastercam, we will test this and solve this problem.
Thank you for your understanding..
Postby ljs66bug » 08 Jun 2015, 18:18
I got it working I had to delete the old software and all the setting files that it dosnt uninstall and restart from the beginning it has crashed 3 times scene running the update version the old one never did lucky it wasn't running a program.
ljs66bug
Postby Support » 09 Jun 2015, 06:38
Fix for Autocad11 .dxf files will be released within new BETA, probably already today.
@ ljs66bug:
How did it chrash? What kind of message do you get?
Postby ljs66bug » 10 Jun 2015, 02:21
When starting the software and one when loading g-code from the file folder the message says
controller stopped working
ljs66bug
Postby Andrea_E636 » 10 Jun 2015, 06:26
Ciao
you can not enter the 'fix' in the newly released stable?
It would be much better for those who are not a good user of the SW.
Grazie
Andrea
Andrea_E636
Postby Support » 10 Jun 2015, 08:13
@ Andrea_E636:
This bug was found right after stable version release, please use latest BETA version which is already published.
Postby Support » 10 Jun 2015, 08:15
@ljs66bug:
No matter which file you try to import, controller stops working?
Postby ljs66bug » 11 Jun 2015, 00:55
Yea it's is any file but at random dosnt happen every time
ljs66bug
Postby Support » 11 Jun 2015, 07:41
Please try running sw and controller on some other computer if possible.
Postby Sacramento » 28 Jun 2015, 15:34
Hello
I updated to the new version (stable as you mention) and now I cannot make the Z axis go bellow zero when I import DXF files. Before the upgrade everything was ok. I am using windows XP.
According to the information found in this forum I installed the new BETA release but the problem remains.
Pls inform if it is possible to get the old version of the software, so I can work without problems.
Sacramento
Sacramento
Postby Support » 29 Jun 2015, 06:45
Can you explain little more in detail this problem?
Please send us your settings and your DXF file.
Postby Sacramento » 29 Jun 2015, 08:41
At start I used the same settings used in the previous version. As it did not work I tried with several settings and the result was similar. The G code developed was quite allright with the Z value according to what was expected, that is -5.000, but the Z axis did not start cutting at -5.000 but allways at 0. I even tried with Z settings of -20.000 and the result was the same, Z cutting at 0. The DXF was not generated by Autocad, but by Illustrator CS3 and CorelDraw 12, and these kind of files worked perfectly with the previous version. I tried to fool the machine making the Z 0 just 5 mm bellow the material surface and the it cutted at Z 0, but did not cut the all parts, some were just cutted half or less. Today we have an holiday so I cannot send you a print screen of the settings. If necessary I'll do that tomorrow. If in the meantime the above information is enough pls let me khow.
Sacramento
Sacramento
Postby Support » 01 Jul 2015, 12:56
This will be tested tomorrow, we appreciate your patience.
Postby Support » 07 Jul 2015, 08:53
@Sacramento: Please send us your settings file and your DXF file.
Postby Florida » 07 Aug 2015, 20:32
MK2/4 latest firmware
CNCUSB v2.10.1505.3001
I am having problems importing DXF files. When the G code is generated the "safe height" is
way off. I have the safe height set to 0.25 inch and the g code is generating a 6.35 inch safe
height. It occurred to me that 0.25in = 6.35mm. I think there is a problem in the calculation
or conversion for inch to mm? It appears to be converting 0.25in to 6.35mm and then to 6.35inches in the gcode. In general settings I have Imperial inches set and in DXF import window "Units = inches" checked. The gcode for the xy axis is correct and z axis passes are correct.
Mark
Florida
Postby Support » 10 Aug 2015, 10:45
Please post your g-code and your .setting file.
Next
