Updated user manual 2014-9-10
Postby Support » 10 Sep 2014, 13:59
New updated version of user manual is finally out there:
http://www.planet-cnc.com/files/CNCUSBController.pdf
Comments are welcomed, if you spot any mistakes please notify us.
Team PlanetCNC
Re: Updated user manual 2014-9-10
Postby JerryBurks » 10 Sep 2014, 15:23
Cool!
Thanks a lot, very helpful!
JerryBurks
Postby evgeninikolov » 13 Sep 2014, 11:39
First of all - really impressive update of the documentation! I am very pleased to see that now the settings and functions are described much more in detail which should ease everybody's live! Than you very much for your effort :-)
One note however - this is not a show-stopper, but you may want to update the table of contents at the end because it is not actual. I personally would put it at the beginning, but this is just a personal preference. I guess also that it could be possible that the page numbers are acting as hyperlinks that point to the actual pages.
Best regards,
Evgeni
evgeninikolov
Postby svberg » 17 Sep 2014, 21:13
Hi.
The Manuals Settings, Lookahead is not what I have on my machine.
Running 2.10.1406.1201.
regards svein
svberg
Postby Support » 18 Sep 2014, 09:15
Evgeninikolov:
Table of contents is now updated and published online:
Table of contents is at the end because when it was on the beginning it turned out as little chaotic.
Svberg:
Screenshots used in latest user manual are from latest software version which is very soon to be released.
Postby svberg » 18 Sep 2014, 09:44
Great, can't wait..
Thanks..
svberg
Postby Firesand » 18 Sep 2014, 22:44
Support wrote:Screenshots used in latest user manual are from latest software version which is very soon to be released.
Wooooo Hoooooo!!!!!
Excellent!!
Firesand
Postby evgeninikolov » 19 Sep 2014, 06:02
Thank you very much!
Can't wait to see the latest version of the software as well!
You guys do a great job!
Evgeni
evgeninikolov
Postby Saracen » 08 Nov 2014, 10:23
Section 3.1.3 - How to connect and setup Output board ?
The connection settings for the Mk2/4 are confusing, as it appears to ask you to connect three output connections (OUTPUT1, OUTPUT2 and OUTPUT7) to four input connections ("S", "1", "2", "3").
The FAQ for the Output Board correctly explains that you use "1", "2" and "3" if using the three relays, and "S", "1" and "2" if using a VFD and two relays.
Also, the screenshot, where is states "Set output pins like this:" shows the Spindle On/Off control set to pin3 and the Speed control set to pin 6.
Again, the FAQ has correct screen shows for the Mk2/4, showing pins 1,2 and 7 in use.
Adrian.
Saracen
Postby ibpsupport » 04 Apr 2015, 12:01
Support wrote:Evgeninikolov:
Svberg:
Are you kidding - nothing chaotic here - table of contents belongs at the beginning of manual - index belongs at the end - case closed. :|
ibpsupport
Controller: Chinese clone
Users browsing this forum: Bing [Bot], obabacan and 3 guests
