New tutorials added on PlanetCNC homepage
Postby Support » 24 Jun 2014, 07:11
We added two new tutorials on our homepage.
How to use movable sensor
How to machine your first work piece
Any comments are welcomed.
Re: New tutorials added on PlanetCNC homepage
Postby Firesand » 24 Jun 2014, 16:22
Those tutorials are fantastic! They are really great. They are simple and to the point. They are wonderful for people who are just starting out with your controllers.
Also, new customers will be much more inclined to buy your controllers if they see sorts of tutorials.
Please make more!!
Firesand
Postby Allen McFarlen » 26 Jun 2014, 20:16
The tutorials and walk throughs of various features are a huge help....at least to me. I find that the naming convention of some of the features and the way that they're implemented to be a bit confusing, so seeing them in action, and more importantly why you click one instead of the other helps clear up the confusion.
I would like to see one on how you go about setting up the software and machine for an ATC. For instance, populating the tool table with tools, positions and etc.
Allen McFarlen
Postby Support » 02 Jul 2014, 10:24
We added new tutorial on our homepage:
How to set correct "Steps Per Unit" (SPU) value
Postby evgeninikolov » 02 Jul 2014, 11:17
Support wrote:We added new tutorial on our homepage:
Andrej,
Do you consider implementing of a wizard that could guide the users with the steps for this process? It give the the same instructions that you have written in your guide (perhaps with the pictures as well) and can then even move the machine and at the end get the feedback from the user. Thus the beginners will not face a steep learning curve and the experts will be not irritated as well as they should be able to choose to enter the values directly in the software.
Same (wizard) goes for the camera setup IMHO.
Regards,
Evgeni
p.s. Tooltips for the fields along with some context help is what I still miss as well...
evgeninikolov
Postby Support » 03 Jul 2014, 07:59
Something similar to SPU wizard, Axis SPU calibration feature is already implemented.
Postby Support » 01 Aug 2014, 08:17
Tool Change
Postby Support » 13 Aug 2014, 09:23
How to use tool change with ATC
Postby Firesand » 16 Aug 2014, 17:32
These new tutorials are great!
Please keep them coming.
I know they take a long time to produce and check for mistakes, but it really makes using your products a LOT easier. A big thumbs up and thanks for the people putting these tutorials together. You are really doing an excellent job. Keep up the good work.
Firesand
Postby Support » 18 Aug 2014, 08:16
Thank you for your kind words. Appreciation like this helps us to do things better and with even bigger motivation. Expect more new tutorials very soon.
Postby Math1010 » 08 Sep 2014, 10:02
These tutorials helped me a lot, thank you!
When is there will be one on the use of transformation matrix?
Math1010
Postby Support » 25 Sep 2014, 13:53
How to set network connection on Mk3 controller?
Postby Support » 09 Jun 2015, 13:25
How to mill and drill double sided PCB using transformations and warp?
We would really appreciate thorough feedback from you guys. For example if there is anything that would need to be changed if there are any confusions etc.
Postby Wolffie » 16 Oct 2015, 08:35
Your tutorials are good, however your English is difficult to understand :cry:
Wolffie
Postby Wolffie » 16 Oct 2015, 08:39
It seems like I cannot edit my previous post as yet, I wanted to add that it seems you are using an automatic translator, the grammar is wrong.
Wolffie
Postby Support » 16 Oct 2015, 08:56
We don't use automatic translator, but we do understand that there are some grammar irregularities.
Thank you for your understanding.
Postby Wolffie » 17 Oct 2015, 13:21
Would you like some help?
Wolffie
Postby ricky1209 » 18 Oct 2015, 22:35
think there's a typo in http://www.planet-cnc.com/faq/moveable_sensor/ which will cause some confusion.. the Mark 3 connector where the text says;
Mk3:
Mk3 provides inputs for user-assigned functions. Tool sensor can be connected to any input pin of
INPUT connector, and assigned in software as Sensor.
The illustration is labeled MARK 2.
ricky1209
Postby Support » 19 Oct 2015, 07:53
@ricky1209: Noted, thank you for notifying us. We will correct this.
Postby Ryadia » 21 Apr 2017, 00:34
There is a problem with the link you provide at the start of this topic for the new tutorials. Either you've moved them, taken them down or there is an error in the URL. I get a 404 file not found error with a link directing me back to the home page. Of course I was never on the home page when I clicked the link!
Ryadia
Ryadia
Postby Support » 21 Apr 2017, 10:43
This is our new blog page: https://planet-cnc.com/blog/
