4 Axis, Postcode and Fusion 360
Postby PCSM-CNC » 12 Sep 2017, 08:59
Hi CNC fans.
I use a MK 3/4 Controller and Fusion 360. Postcode i got one from Internet called PlanetCNC.cps.
I want to use the 4 axis but by generate gcode i`ll get an error.
Is there an other, maybee a newer version whitch can use the 4 axis?
Somebody have a manual for programm 4 axis and gcode?
And then there is an other problem.
If i generate a gcode, basicly the G43 is written in the tap data.
I must delete the G43 by any tool cause the toolpath are wrong if i dont delete them manual.
Regards Alex from germany
PCSM-CNC
Re: 4 Axis, Postcode and Fusion 360
Postby Support » 03 Nov 2017, 10:44
PlanetCNC forum will be closing within next month.
PlanetCNC Support team
