Problems jog speed setting and OVRD
Postby off.messina » 11 May 2017, 14:11
Hello
Why the speed and jog and ovrd of the axes do not exceed the value of 2711.20? I need the axes to go faster but I can not. Where am I wrong?
settaggio iniziale.setting
This is my setup:
(49.49 KiB) Downloaded 10 times
off.messina
Re: Problems jog speed setting and OVRD
Postby Support » 17 May 2017, 09:07
You have a very high Steps Per Units Value for all three axes.
Since max speed of machine is conditioned by steps per units values and step rate of controller max speed of your machine is 2711. I would recommend that you lower your steps per unit values, cca. 1600.
