Scaling
Scaling
Postby seasonablyrustic » 23 Nov 2016, 20:22
Using ArtCam to generate G-Code. Set to inches. Load G-Code fine and routing is fine. However, scale is off. Simplified, G-code set to generate a rectangle 10inX6in. CNC USB shows it routs 10x6, but actual is about 75% or 7.5X4.5. Scale is set to 1.00. I also have another router using Mach 3, same G-Code and dimensions are 10X6
seasonablyrustic
Re: Scaling
Postby Support » 24 Nov 2016, 07:03
Please post your settings and your g-code. Thank you.
