Problem I didn´t know
Postby udoscnc » 29 Oct 2017, 16:25
Hi there,
sorry about my bad english but my homecountry is germany.
I am a newcomer in cnc and so I did not know if I am to stupid or it is a really problem!?
I am working with a cheaper milling machine from ebay, the software they recommend is
cncusb.
I got the machine working with a workpiece created by cad and output *dxf
The machine is calibrated by cncusb so that the length should be equal in x and y axis.
The tests will be OK.
But when the machine is milling a workpeace, nearly all the length are different!!!???
I was chanching the stepmotors to try out if there is a problem in hardware - nothing
changes!
The shafts are working smooth and I could not see any physical problem.
Is it possible that I forgot any attitude in cncusb that produced the problem?
At small circles or rectangles the machine works very well, but at more complex parts
the polygon ends in uacceptable distance (workpiece 6-7cm a distance in x and y more
than 10mm!)
If someone has an idea I would be so glad
Udo
udoscnc
Re: Problem I didn´t know
Postby Support » 03 Nov 2017, 10:46
PlanetCNC forum will be closing within next month.
PlanetCNC Support team
