Controlling AC Servo for "Spindle control"
Postby cdfleischmann » 05 May 2017, 00:26
Hello folks, sorry if this has been asked before, but after some hours of googling and reading through forums, I a still a little bit stuck.
What I a trying to do is use my mk3/9 axis planet cnc controller (with or without) the output board to control a servo. I am wanting to use an AC Servo motor as my spindle motor.
The spindle motor I am looking at is here: http://www.ctbservo.com/Products/delita.aspx?pid=49&nid=3&vs=&id=131 which has a good user manual here:http://www.ctbservo.com/UpLoadFiles/OtherFile/20151121031152.pdf and this servo motor is controlled by the following http://www.ctbservo.com/Products/delita.aspx?pid=61&nid=3&vs=&id=94 which seems to suggest it accepts the following as per the attachent/image and its manual here: http://www.ctbservo.com/UpLoadFiles/OtherFile/20151121031822.pdf
What I am niavely trying to do is set up the servo drive similar to that of the VFD that I have and use, like the BLOG post here: https://planet-cnc.com/controlling-spindle-output-board/
Any thoughts or recommendations as to whether I can do this or not? Ideally, I want to control an AC Servo motor (for its torque/curve/RPM) ratio to control a belt driven BT30 ATC Spindle for metal CNC'ing.
Any help or advice much appreciated. I am of course asking the AC Drive manufacturer, but I think its more a wiring and planet cnc thing than a AC Drive "issue"
Thanks again,
Chris
cdfleischmann
