Control Box wiring help
Postby rbedard77 » 29 Apr 2017, 11:58
Hey all, I am new to CNC's and could certainly use some help. I purchased the MK3 controller and the 344 enclosure with accesories. My question is more around the DB9 plugs and 4 pin aviation plugs on the enclosure. I would like to use the DB9 plugs for the motor drivers. I am not sure which wires go where on the male plug end coming from the table to the control box. Any ideas?
rbedard77
Re: Control Box wiring help
Postby slbat » 19 Jun 2017, 20:21
Have you checked out the manual...You can download them. They're not too bad
Enclosure Build Part 1
http://planet-cnc.com/wp-content/upload ... _Part1.pdf
Enclosure Build Part 2
http://planet-cnc.com/wp-content/upload ... _Part2.pdf
If those don't address your exact concerns, you might have to use the MK3 Manual and extrapolate your you specifics.
MK3 Controller Manual - includes general wiring guidelines
http://planet-cnc.com/wp-content/upload ... lerMk3.pdf
Lots of reading, Good Luck
slbat
