Mk3 PWM connection with Spindle motor
Postby albin.jakobsson » 13 Apr 2017, 09:36
I'm new here in the CNC community and I just bought a Mk3/4 controller with enclosure and accessories kit. I have a HX-WS400 BLDC motor driver (attachment) and Spindle motor (with 48V power supply).
Now I want to control the speed of this spindle motor with my Mk3/4 controller. I've search around here on the forum but I couldn't find the answer I was looking for.
If I understand it right I can connect the "PWM", "EN", and "F/R" connections from the motor driver card to the output pins (6,2,1) on the Mk3 controller and then I should be able to control the speed with PWM signals and on/off in the software? Do I need to connect a common ground as well?
Am I correct here or am I missing something? Do I need an output board, or connect something through the optocoupler? I haven't tried anything yet, I wanted to ask you experts first :D
Thanks in advance
Albin
HX-WS
albin.jakobsson
Re: Mk3 PWM connection with Spindle motor
Postby Support » 13 Apr 2017, 14:12
Yes connect also GND from controller. Set speed output as PWM and other as M3 ON/OFF(this one would probably be connected to EN terminal).
Postby albin.jakobsson » 13 Apr 2017, 14:42
Support wrote:Yes connect also GND from controller. Set speed output as PWM and other as M3 ON/OFF(this one would probably be connected to EN terminal).
Thank you, I will try this!
albin.jakobsson
Postby albin.jakobsson » 20 Apr 2017, 08:49
I haven't had time to test it yet, but I was wondering about the output board. Why do I not need to connect it via the output board? According to the https://planet-cnc.com/using-output-board-planetcnc-controllers/ I should connect the spindle motor controller through the output board.
Could connecting the spindle motor controller directly to the mk3/4 output pins be harfull, since there is no relays or such?
Thanks in advance!
albin.jakobsson
Postby Support » 21 Apr 2017, 10:42
Please check the motor controller voltage levels of control inputs.
Postby albin.jakobsson » 21 Apr 2017, 11:43
Support wrote:Please check the motor controller voltage levels of control inputs.
The voltage level of the control inputs are 5V.
albin.jakobsson
Postby Support » 21 Apr 2017, 11:58
Please send us user manual for this unit
Postby albin.jakobsson » 21 Apr 2017, 12:20
Support wrote:Please send us user manual for this unit
This is the only information available
Parameter(BLDC Motor):
1.Spindle motor: new brushless DC motor (imported NSK Bearings)\
2.Operating voltage: 48VDC brushless drive required, the motor can operate\
3.Power: 400W
4.Speed: 12000r / min
5.Torque: 0.5294 (N.m)
6.Insulation resistance:> 2 megohms
7.Dielectric strength: 400V
8.Diameter: 57mm (fixed body parts is 55mm)
9.Chuck portion length: Arbor parts 35mm, (containing nuts and sandwich 43mm)
10.Clamping portions diameter: 16mm
11.Motor Overall Length: 172mm (comprising gripping parts and motor)
12.Spindle Weight: 1.1KG
13.Spindle radial runout around 0.01-0.03.
14.It can be used for engraving metal or non-metal and other materials.
15.The spindle comes with forced air cooling, you can work long hours
Brushless DC (BLDC) Motor Controller:
Features:
1.Model: HX-WS400
2.Working voltage: DC18V-DC52V
3.The drive current: rated 10A, peak 15A.
4.Drive power: ≤500w (operating voltage related)
5.Closed loop steady speed, large load on the motor can maintain speed
6.Pure hardware design, high-speed, high noise immunity
7.External potentiometer control, 0-5V analog voltage and PWM speed (MACH3 Control)
8.Reversible control, soft switching function
9.Overcurrent and short circuit protection indicator (red LED)
10.With EN enable control
Wiring instructions:
1.DC + DC-: DC voltage input of DC18-52V
2.U V W: motor phases
3.HALL +: Hall positive supply
4.HA HB HC: Hall signal cable
5.HALL-: Hall negative power supply
6.+ 5V: control signal power supply + 5V
7.VR: speed control signal input terminal
8.GND: control signal power to the common terminal
9.F / R: forward / reverse control signal terminal
10.PWM: PWM frequency (MACH3)
11.EN: Enable control input
Function Description:
Speed mode:
1. The default speed potentiometer, can be directly through the rotary potentiometer speed
2. Analog control, VR pin is connected to a voltage signal input terminal, GND pin to ground (voltage range 0-5V) (NOTE external voltage signal control necessary to remove the potentiometer control to take effect, whether the person can not control)
3. You can use an external PWM signal input speed control, external PWM input requirements: level 3.5-12V VPP, frequency 1K-10KHZ, suitable for MACH3 spindle speed control, (note the external PWM signal control necessary to remove the potentiometer control It takes effect, whether the person can not control).
Motor Run / stop control (EN):
Control terminal EN relatively GND-off can control the motor to stop and run. EN pin is floating the motor is running, when the GND terminal is connected motor stops.
Motor forward / reverse control (F / R):
Control F / R and + 5V-off operation can be controlled direction. When the F / R and + 5V is not connected, the motor is running counter clockwise, otherwise the motor running in a clockwise direction
400W cooled spindle motor for power:
1.Input voltage: AC110 / 220V 50 / 60HZ, can be switched, universal
2.Output voltage: DC48V
3.Output Power: 400W power with temperature control cooling fan
4.Power Weight: 0.9KG
5.Power dimensions: length 215 * W 115 * H 50
albin.jakobsson
Postby albin.jakobsson » 24 Apr 2017, 14:20
This is probably a really basic question, but I'm really new to this and I'm trying to learn it all from scratch.
So, I went a head and bought the output board and wired it as follows:
Output board - Mk 3/4
“S” – OUTPUT6
“0” – GND
“1” – OUTPUT1
“2” – OUTPUT2
“3” – not connected
Power:
"12V" - 12V+ from power supply
"GND" - V- from power supply
From the VFD (Spindle motor controller) I connected:
"Enable" - 1
"Fr" - 2
"Gnd" - GND
So far so good, but now I am confused about how I will control the spindle speed.
As I posted above, I have both a "PWM" connection from the spindle controller board (3.5V 0-10kHz) and a "VR" speed control signal input terminal (0-5V).
How should I connect the Spindle motor controller in the best way?
1. Connect PWM from spindle controller directly to MK3/4 output pin and generate a 0-10kHz signal from software.
or
2. Connect 0-10V out from output board to VR on spindle controller (and limit the output to 5V using the calibration? What do I set the frequency to in the software, what range does the output board use?
Thanks in advance!
albin.jakobsson
