Plasma thc not working
Postby gabionose » 07 Apr 2017, 05:07
Hello, i bought a Proma THC 150 for floating head , connected with my mk3/4 board , gnd---com , jog 3----up , jog4----down , as i use axis number 2 to control Z , the problem is that when i run the program the thc control is not working , PROMA THC 150 sends signals to go up or down but the mk3/4 refuse to jog .
Please help me .
setari.setting
seetings
(50.05 KiB) Downloaded 20 times
gabionose
Re: Plasma thc not working
Postby Support » 11 Apr 2017, 08:58
Please configure your settings so that your Z axis is on Axis 3 and Y axis is on Axis2.
Please connect your THC control signals to Jog pin 7 and Jog pin 8 of jog connector.
https://planet-cnc.com/how-to-connect-and-setup-torch-height-control-thc-for-plasma-cutters/
Postby Wastelandfab » 20 Jul 2017, 14:08
I'm using TNG with proma thc 150, and have pins set up to incline/decline using pins 7 / 8 on jog connector. When I run "tst" it shows the IO moving, but the axis itself does not move.
When I run a program, the thc reads my machine voltage, but does not move z axis. I'm 99% sure it's wired correctly. Also I have a set to axis 3. Any suggestions?
Wastelandfab
Postby Wastelandfab » 24 Jul 2017, 08:55
I have followed these suggestions, and my proMa reads voltage but does not raise our lower. Using planet cnc tng.. It acts as though it's not activated, and I can't find anywhere to turn on, other than just setting to x axis
Wastelandfab
Postby Support » 31 Jul 2017, 14:33
