what types of inductive proximity switches ( MK 3/4 Board )
Postby safran » 29 Oct 2016, 08:42
Hello, I'm Safran from Germany.
I want to connect inductive proximity switches for the limit-switches with my MK3 / 4 Board.
1. Is it better to use NPN or PNP switch types?
2. How must they be connected ( +24V and GND to switch, switch-output and GND to board? )
3. I want to use one switch per axis. Am i right in this case?
Thanx for answers
Safran
safran
Re: what types of inductive proximity switches ( MK 3/4 Boar
Postby Support » 07 Nov 2016, 12:10
http://planet-cnc.com/how-to-connect-pr ... it-switch/
If you would use our adapters, PNP would be recommended:
http://planet-cnc.com/using-optocoupler ... ontroller/
You can use one switch per axis, but usually two limits per axis are used.
Postby marco.m » 28 Nov 2017, 13:37
i need some help whit setting up pnp limetid switch on the mk3 controler
i understand that you need a optocoupler and find the shematic how to connect the sensor
see link https://planet-cnc.com/using-optocouple ... ontroller/
then i looking to the 12v shematic
but what i not understand where you take the 5 volt power
on the limet connector you dont have 5 volt
do you need separte power supply ?????
or can you take some where else 5 volt
thanks
marco.m
Postby Support » 14 Dec 2017, 10:48
You can use 5V from Axis or Output terminals
