Output board query
Output board query
Postby molliemilo » 15 Oct 2017, 09:29
I have a Mk3/9 controller with an output board.If I use the huanyang 2.2kw with the onboard panel controller I can go through the entire frequency range and their associated speeds.When I connect the output board,and spindle is idle,I get 10 volts for the speed control.However,when I run the VFD through the output board it gives me a max. frequency of approx.F250 and an approx. speed of 15000rpm.My question,as a newbie to all this electronic stuff is,do I program the software to run at 24000 rpm and adjust the voltage trimmer until I achieve 24000 on the VFD display? Max .voltage in parameters is set at 8 and when running at approx. 15000 rpm gives me a voltage of 8.36 or thereabouts.Any suggestions,please.
molliemilo
Re: Output board query
Postby Support » 19 Oct 2017, 11:57
PlanetCNC forum will be closing.
PlanetCNC Support team
