Output board query
Output board query
Postby molliemilo » 15 Oct 2017, 09:29
I have a Mk3/9 controller with an output board.If I use the huanyang 2.2kw with the onboard panel controller I can go through the entire frequency range and their associated speeds.When I connect the output board,and spindle is idle,I get 10 volts for the speed control.However,when I run the VFD through the output board it gives me a max. frequency of approx.F250 and an approx. speed of 15000rpm.My question,as a newbie to all this electronic stuff is,do I program the software to run at 24000 rpm and adjust the voltage trimmer until I achieve 24000 on the VFD display? Max .voltage in parameters is set at 8 and when running at approx. 15000 rpm gives me a voltage of 8.36 or thereabouts.Any suggestions,please.
molliemilo
Re: Output board query
Postby Support » 19 Oct 2017, 11:57
PlanetCNC forum will be closing.
There are multiple reasons, mainly spam, because of which we need to constantly maintain the forum which prevents from users have quick support.
Main support operates via support tickets on our home page: https://planet-cnc.com/support/
We really recommend that for any support questions or info regarding our products, you use this ticketing system.
You can also use our support mail at: support@planet-cnc.com
We will continue our community support forum on CNCZONE: http://www.cnczone.com/forums/planetcnc/
On CNCZONE users can discuss anything related to PlanetCNC or CNC.
PlanetCNC Support team
Return to Mk3 controller
Users browsing this forum: Bing [Bot] and 1 guest
