Problems with floating head.
Postby Mr.Emo » 26 May 2017, 20:24
I am trying to figure out how to get my floating head to work.
There is a NC switch that is being held down by a plate that the torch sits on. So the normal state of the NC switch is NO. When the switch is pushed up it goes back into the state of NC.
I have connected the wires into the input board 1 and 2. I have tried to change the input from sensor and tool sensor but I can't get it to work.
G00 Z20
G10 L7 R-3
G00 Z1
M03
G00 Z6
G04 P1000
G00 Z1
This is the code I am running. When I manually activate the NC switch to simulate the torch hitting the metal nothing happens. Not as a sensor or a tool sensor. I have also tried switching between NC and NO but neither seem to work.
I also have a limit switch on the Z axis. When I activate this however the Z in the planet cnc software jumps from whatever the Z value is to Z -67 and then proceeds to go up to Z6 before continuing with the code G04 P1000 and G00 Z1.
Any tips?
Mr.Emo
Re: Problems with floating head.
Postby Mr.Emo » 29 May 2017, 09:21
I figured this out. Was a problem with offset in the program. Also connected the sensor to the wrong terminals.
Mr.Emo
