C# example throws exception
Postby Trumo » 05 Jul 2013, 11:08
I tried running the basic example after finally downloading the DLL from the website but nothing happens if I press any button except init. When I perss init it crashes with an unhandled exception:
System.TypeInitializationException was unhandled
Message=The type initializer for '<Module>' threw an exception.
Source=CNCUSBControllerAPI
TypeName=<Module>
StackTrace:
at PlanetCNC.API.CNC.Initialize()
at CNCUSBControllerAPI_CSharp.TestForm.btnInit_Click(Object sender, EventArgs e) in C:\Kit\CNC API\CNCUSBControllerAPI_CSharp\TestForm.cs:line 31
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at CNCUSBControllerAPI_CSharp.Program.Main() in C:\Kit\CNC API\CNCUSBControllerAPI_CSharp\Program.cs:line 18
InnerException:
Message=Debugger detected - this software cannot run with Debugger.
Source=CNCUSBControllerLib
StackTrace:
at A.
at .cctor()
InnerException:
Trumo
Re: C# example throws exception
Postby Andrej » 05 Jul 2013, 20:17
You can not use API from debugger. Compile application and start it without debugger.
Postby Trumo » 08 Jul 2013, 09:30
Ok I tried that too but things look pretty much the same. When I press init the only message I get is Initialize FAILED
Trumo
Postby Andrej » 08 Jul 2013, 10:23
Do you have your .exe in same folder as CNCUSBControllerAPI.dll and CNCUSBControllerLib.dll?
Postby Trumo » 08 Jul 2013, 10:28
Yes they are both in the folder
Trumo
Postby Andrej » 08 Jul 2013, 10:41
And you are not running from visual studio? You doubleclicked your .exe?
You do have connected controller?
Is our software working with controller without problems?
Postby Trumo » 08 Jul 2013, 10:45
Yes I have connected the controller and it runs perfectly with your CNC USB software. After testing it like this I exit CNC USB and run CNCUSBControllerAPI_CSharp.exe
In CNCUSBControllerAPI_CSharp.exe the all the buttons don't do anything other than Init. When I press init it works for a little then says initialize failed. It does the same even if the controller is not connected.
Trumo
Postby Andrej » 08 Jul 2013, 11:09
And you have CNCUSBControllerAPI_CSharp.exe in same folder as CNCUSBControllerAPI.exe? This should work.
Do you use latest beta version?
Try this.
Code: Select all
Set cnc = CreateObject("PlanetCNC.API.CNC")
cnc.Initialize
MsgBox "Serial: " & clng(cnc.Serial)
MsgBox "Position: " & cnc.Position
Set cnc = Nothing
Copy this to file named "test.vbs" and double click it. This file should be in same folder where you install beta software.
Postby paulrengifo » 29 Sep 2014, 21:34
Greetings friends. can you help me with two questions please /
Because I get 1 license = false, if cncusncontroller enables all functions with the license I have.
2.The image(Testform) below corresponds to the run direct CNCUSBControllerAPI_CSharp.exe file, but opening to change the buttons and make a custom application, there is a bug that I show in the second image(error.png)
please help me
paulrengifo
Postby Support » 30 Sep 2014, 11:51
You cannot run your application directly in visual studio. Please read all posts that were already posted in this topic.
Postby grovalmitch » 28 Apr 2015, 07:51
More about....C# Exception Handling
Mitch
grovalmitch
